Trying to locate fuse in washing machine
Last time it was turned on, it blew the fuse in the electricity mains fusebox. Have repaired mains fuse but now washing machine shows no power light (or electrical response of any kind). Can anybody advise me where I can find the washing machine fuse location please?
  • 3 more comments
  • larry_kin92 Jul 26, 2009
    Thanks for your reply onetatm8,
    Sorry, I should have also mentioned that the machine has been leaking a little water previously. My guess is that this probably is the cause of the fusing problem as it happened as the machine was filling and before the actual wash began. My hope is that I can locate and rectify the leak, but I do need to also locate the fuse (if it exists) and replace it with a new one.
    So I am still looking for the *location* of the fuse Please.
  • larry_kin92 Jul 28, 2009
    Thanks for the advice Rob, i should have mentioned that this is an Australian Hoover 1100f front loading washing machine. Fuses are not built into plugs at all here. Have checked the loom (removeable cover) with no joy - just wires. no sign of it to motor or pump or from the rear view of the controller. am reluctant to remove that as it means removing from dial which i don't know how to do. any advice on removing the dial safely? It is recessed & plastic.Cheers & Thanks!
    Cobber!
    Gotcha Rob, thanks for that, must admit to having posted on another similar site also. the advice there hinged on the 'obvious' in plug fuse (buncha Poms i'm guessing ;-)
    just find it hard to reeally believe there's no fuse, even if you're right with your prediction :3(
    in the bush here, tas, things move slowly. will post the end result in time but think i'll ring around first - and hope. $$ being far rarer than Flying Pigs at the moment .....
  • larry_kin92 Aug 12, 2009
    Sorry for the delay in responding Rob.
    You were right, (TIP / NO FUSE / SHOP) am now on the hunt for a replacement.
    btw. i googled Tasmanian Devils Stunt Team but with no joy. Any links out there?
    Thanks again
  • larry_kin92 Sep 04, 2009
    NOT "Generic problem for all Washing Machines"
    Instead "Generic problem for most FRONT LOADING Washing Machines"
    Better late than never!
    Most *front loading* washing machines have a rubber boot (seal) which the door closes into to prevent water leaking when the machine is in action.
    In time these boots tend to rub / perish and will then leak water. If the leak is near the electronicly controlled door latch, this will short the power to the machine which will then cease to function.
    Replacing the blown door latch switch will bring the machine back to life, saving the need to purchase a new machine.
    Of course this job is only to be performed with the electric power disconnected.
    Fixed! Learn something new every day.
    Solved by OP. Thanks to all advisors.
  • 850 Answers
If it bows the mains then dont try it again!
get it checked out ASAP!
Posted on Jul 26, 2009
  • 2 more comments
  • ROB Jul 27, 2009
    i doubt that it would have a fuse but if it did it would have to be between the motor & the cord! [Disconnect the power cord first!]
    so the only other place would be in the loom to the control panel!
    just follow all the wires but as i said i doubt it would have one
    I hope this helps!
    Cheers Rob
  • ROB Jul 28, 2009
    OZY! OZY! OZY!
    OY! OY! OY!
    Im in nsw
    ok it seems that the motor has dead shorted & needs to go to the TIP! lol
    Dont try removing anything else as there is not going to be a fuse there either!
    its a SHOP JOB!
    Good luck! Rob.
  • ROB Jul 28, 2009
    im from tassie m8 you may even know of me as i had
    The TASMANIAN DEVILS STUNT TEAM got my world record car crash in 1980
    Cheers Rob.
  • ROB Aug 12, 2009
    i googled it too with no luck & as all my stuff was stolen i cant show any body anything but the ADVOCATE has archives on my first live show there in 1976
    there is other stuff in other papers around OZ
    I had big show in Launy [ suicide on wheels] worked with Dale Buggins doing ford ad etc. & mad max aspen
    lots of stories lol
    ok good luck with the washer cobber
    Cheers rob
    Ps : Google my uncle TEDDY SHEEAN from Latrobe
    Victoria cross is coming soon
My maytag stopped working after we blew a main breaker and reset it. We discovered a blown fuse between the water level switch and water valve. Every time i replace the fuse it blows instantly
there,s a water leak which its causung your problem
take a look inside electrical compartment water cause more problems that the electricity and comment
Sep 15, 2015 | Maytag Washing Machines
Where is the main relay located on a 2007 nissan sentra 2.0. It's not in the fuse box. It doesn't let power go to anything when it's blown I have a new one but can't find the old one to change it out.
http://www.nicoclub.com/FSM/Sentra/2006_Sentra/pg.pdf
if this is AKA the IGNITION relay see page 44 on that link i included
click on the last link for paul's pictorial on how to access that inner fuse box
the inner fuse box, labeled A, and that ignition relay is on the flip side of that whole box! i dunno if you have to unbolt the box and flip it over to see those 3 relays listed on that page = ignition, blower motor, and accessory
2007 2012 Nissan Sentra Electrical Fuse Replacement Guide 013
that pic of the white fusebox has those nuts holding it on the chassis, hopefully you can get to the other side of the fusebox by unbolting those nuts and flipping it
Nissan Sentra Electrical Fuse Replacement Guide 2007 To 2012 Model Years...
Apr 04, 2015 | 2007 Nissan Sentra
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
My dryer blew a fuse in our breaker box. I have reset the fuse in the electrical box but the dryer still wont turn on. I have tried to unplug and replug in the machine. The timer does not even tick when...
check both fuses if its an electrically heated dryer as you need 240 volts to make the motor and timer both work because the motor is on 1 leg and the timer is on the other leg of power and the element is across both legs for 120+120 volts = 240 volts needed to run the unit
Jun 04, 2011 | Dryers
I went to start my triumph and let it idle for about ten minutes. I began to leave and as soon as I pulls the throttle it died. I then opened the choke and restarted it but as soon as I gave it gas it...
Sounds like its been sitting a while and you have to clean the jets in the carb.
As for the electrical problem.
Sounds like it could be the ignition main fuse. There is a main hot wire off the battery that goes to your ignition switch that is always hot, when you turn your key it sends that power to everything else.
That hot wire has an inline fuse that is not in the fuse box. It probaly blew from trying to start the bike repeatedly and the wires got hot and the fuse blew. Clean your carbs, and check that fuse.
Dec 02, 2010 | Triumph Legend TT Motorcycles
Washing Machines Logo
845 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
