Question about HP Pavilion dv4000 Notebook
Can't install autocad 2010
It says autocad already installed, though there is nothing in add or remove program. cant even restore system as its a new laptop so there is no earlier restore point
  • tarunmbd Jul 26, 2009
    still says the same thing
  • 746 Answers
My Dear! Go to start then click and open Run type in regedit then open HKEY_LOCAL_MACHINE click on software find the software name such as Autocade delete their registry file. After deletion you should restart your computer and reinstall the autocade. I hope your problem will be solved.
Thank you
Posted on Jul 26, 2009
How can i install autocad 2010 please tell me
Posted on Dec 17, 2009
  • kami_rock55 Feb 09, 2011
    just delete your registries by ccleaner
How to update autocad 2010
AutoCAD 2010 Update 2
You can apply Update 2 to AutoCAD 2010 running on all supported operating systems and languages. Be sure to install the correct update for your operating system.
You do not have to install Update 1 in order to install Update 2. Update 2 includes the most recent fixes, as well as all fixes included in Update 1.
or you can contact support at link below:
Contact Us Autodesk Knowledge Network
Jan 22, 2015 | Autodesk AutoCAD LT 2010 (License Only)...
I am not able to uninstalled autocad 2006 through Add/remove programs. "Fatal Error while trying to uninstall Autocad 2006.
Reinstall & unistall the programme
or
Use the System restore Utility to restore it to the point before you install the programme.
Hope it helps.
Feb 03, 2011 | Autodesk AutoCAD 2006
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
How to install autocad 2004 in windows 7
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
Aug 04, 2010 | Autodesk AutoCAD 2004 for PC
Cant uninstall autocad 2010... the uninstall program from windows does not work
Use your DVD/CD to reinstall and there is a function on the CD to remove the program.
or
You can use the microsoft restore utility to restore to the point before you install the program.
Hope it helps.
Jul 16, 2010 | Autodesk AutoCAD 2010
I cannot install my autocad 2010 because it says that my processor is not sse2 compliant. is there a way to install it for free?
Hi
I'm sorry you can not use the program with your old computer, the requirements are.
  • Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010 I will try to not geek out and confuse you on this post. With AutoCAD 2010 there is an AutoCAD 2010 System Requirement to have a CPU (essentially the computer’s brain) with SSE2 support. SSE2 is an Intel CPU instruction set (SIMD Extension 2) which is essentially technology to replace the old MMX extensions which are half as slow in many data and math operations. Most current systems will support SSE2 except an old AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010:
In developing software there is a limit on how old of technology you can effectively support without impacting current hardware and software users. In the case of AutoCAD 2010 adding the SSE2 requirement this increases performance for customers using current hardware. Many areas improve in AutoCAD such as OSNAPs.
I said I would not geek out so I will not go into details on floats, floating point, and registers. Your experience may vary but the change was made for some performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!
End Quote.
Dec 15, 2009 | Autodesk AutoCAD 2010
I have an issue with autocad 2010 on windows 7. im trying to reinstall it, and it says its already installed, i cleaned the obvious registry values, used windows installer clean up, and used a registry...
have you tried add/remove programs in control panel, then reinstall? if it was recent it could be a service or process still running in the background. check the task manager and make sure there are no applications or process still running. please rate me if this helps. thanks and good luck!
Sep 18, 2009 | Autodesk AutoCAD 2010
Cannot uninstall Avanquest SystemSuite? 9 Professional; need urgent help
Bro, I can solve this
These suites get way to crazy because of how they try to force people not to copyright them. Within your install process a rootkit was installed and it wont come out of your computer...do what I did...
Go to www.Myspace.com/KyleGallas to watch a video of a Custom Gaming Computer with all the must have security features...The PC has like $4,000 retail for like $659. It comes with a ton of extras like 133 Nintendo DS Games, Fallout 3, Adobe CS4, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
May 31, 2009 | Avanquest System Suite 8: Windows
Autocad 2006
if you still have the install software run it and select the repair option, then you should be able to remove it from add remove programs after a reboot.
Oct 25, 2007 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
8,675 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
