I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
SOURCE: McCulloch mini mac 35. Badly worn chain
you can go to youre local LOWES, or SEARS and pick up an oregon 14" S49 chain.
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
SOURCE: not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
