Question about LG 26LG30 26 in. LCD TV
My LG 26LG30 has power button blinking, won't respond or turn on.
My LG 26LG30 normally has a red light indicating that it is off, and this turns to blue when the set is turned on.
Now, the blue light and red light are blinking alternating, red, then blue, then red again, about 1 second each.
The TV set will not respond to either manually turning the set on and off or using any button on the remote.
Turning it off by unplugging it from the wall makes no difference when I plug it back in. There are no peripherals attached to the TV set.
Any ideas about what might be wrong? The set is about 1.5 years old.
  • wmhogg Jul 26, 2009
    I checked everything and it is still doing that blinking and will not come on.
    I assume now that it is the hardware. I may have bought a service plan for that TV.
    Thanks for your assistance!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the remote control batteries. Now check the cable inputs at the back). If still the problem persists then the problem is with the transformer inside the TV which has gone bad due to a short circuit inside it and that is the reason due to which the TV is facing the issue you described. The transformer core contains very high voltage even when it’s off. If you don’t have any experience then I will advise you to get it repaired/ replaced from a qualified technician.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 26, 2009
2 Suggested Answers
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
IN POWER SUPPLY SECONDRY SIDE ( 5V,12V,&24V) ALL CAPASITER REPLACED SET OK
Posted on May 25, 2010
My lg 42ln5300 tv has the red indicator light on but when i try to turn it on blinks and it won't turn on
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.If blinks continue without any pause, the main board is faulty.
Sep 18, 2015 | LG 42LN5300 42" LED TV 1920 x 1080, 60 Hz,...
Lg 50pc3d plasma
Procedure is
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
Jul 07, 2013 | Universal Remote Control Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
I forgot the code of my universal remote control of my lg tv?
Hello
Four digit universal remote codes for LG are:
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Sep 28, 2011 | LG Televison & Video
Cannot find correct remote code for lg 37lh2000za
Hello
Universal remote codes for LG are:
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
May 26, 2011 | Televison & Video
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Lg 26lg30 light blinks red blue wont turn on. When unpluged light flashes blue for a minute then turns off
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
Nov 06, 2009 | LG 26LG30 26 in. LCD TV
LG 26LG30 26 in. LCD TV Logo
993 people viewed this question
Computer Repairing
Computer Repairing
