Question about AEG B3101-4 Electric Single Oven
AEG Competence B6139 -M and the oven switches off as door closes
The oven starts OK and then as you try and shut the door the fan and oven switch off. By careful jiggling of the door as you close the last few mm's you can get it to stay on. I think it is linked to the Energy Saving door switch mentioned in the last paragraph on page 8 of the user manual.
looking to find which part needs replacing and if a relative novice like me can do it!
2 Suggested Answers
  • 3463 Answers
SOURCE: I need a rubber seal for an AEG B6139-M Competence door oven
If you are in the u/k, then look in telepohone directory for Service Force, they are the service agents for AEG.
Please rate my solution.
Posted on Jul 19, 2009
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
when i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
May 26, 2011 | AEG B4101-4 Electric Single Oven
I have an AEG competence 5020 B fan oven (single) which has a very noisey fan, does this need a new motor and can I fix this myself?
Remove the oven, open the back, remove the fan, and clean with WD40, afer the fan is dry, fit the fan back into the housing, replace back and put into cabinet, switch on low, if the fan makes a whirring noise, or unusual squeeking replace the fan, if however the fan sounds normal and good pressure when door is open, it should be okay. If you require a part go to
Hope this is helpful
May 17, 2011 | Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
May 20, 2010 | Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Jan 06, 2010 | AEG Ovens
Jul 16, 2009 | AEG Ovens
AEG Competence Double Fan Oven Fault
Sounds like oven element is faulty, disconnect it and try again, if it does not trip, then it is definately the element..
It is easy to replace.
Plz leave feedback.
Sep 22, 2008 | AEG B2100-4 Electric Single Oven
AEG B3101-4 Electric Single Oven Logo
169 people viewed this question
Top AEG Ovens Experts
Sal De
Are you an AEG Oven Expert? Answer questions, earn points and help others
