Question about Sony Handycam DCR-SR200 Camcorder
Dcr sr 200 low light on a display
Display is almost dark, it is very difficult to see what´s on. It seems like a problem with the low light on a display. Could you solve it?
  • 4 Answers
I just got done fixing mine with the same problem. Initially the camera would "short out" when I opened the display, then went totally dark. I got the cable above that Amjii suggested (even though it is listed as for the SR300), and started taking it apart. The hardest part is remembering which screws go where. I did it in under an hour. I figured what the heck, Sony wanted at least $250 to fix it, and the machine didn't cost much more than that!
If you attempt this, there are a few things that will help: 1. It is easier if you take both sides of the outer shell off first. 2. Don't break the tape on the hard drive on the bottom. When you take the shell off the hard drive can fall out and rip the tape. 3. The display cover comes off by turning the display and removing the screws near the hinge. You won't be able to do this until you remove the left outer shell with the display on it. 4. You need to have an understanding about how the tapes go in. The biggest inner tape (under the tiny tape that doesn't need to be removed!) just pushes in with the tabs on the sides. The others have a black or white connector that either A. pulls straight out a little bit, and then gets pushed back in when you get the tape in or B. hinges out and gets pushed back in when you get the tape in. There is a tape on the upper body that I found easier to disconnect on the right side and replace the left first then back into the right side. 5. There is a small tape that goes to a switch on the hinge that turns the display upside down when you flip the display. That was the hardest for me to figure out when putting it back together because I didn't pay attention when opening. The replacement tape get wrapper around the hinge counter-clockwise and the clipped with a black clip onto the round hinge. Then when you put the grey and silver covers back onto the hinge, the small switch is sandwiched between and is held in place under a small metal flange thing. Make sure the glued spots (there are two) are replaced.
I understand that none of this will make sense until you start to do it yourself. If you are hesitant I would have a service center do it. I just saved myself at least $250!
Posted on Sep 15, 2009
  • Sony Master
  • 586 Answers
The problem is in your camera is PWB FP-610 and its part number is 1-871-457-21 which needs to be replaced, and the problem will solve, and infect the said part can only change by an expert because the procedure is bit difficult therefore contact any expert or prefferably contact SONY SERVICE CENTRE nearby.
Thanks for using fixya.
Posted on Jul 26, 2009
DVD recorder 440HX. Why is display dark and difficult to read numbers letters on display window?
Because the display has developed an electronic problem that needs addressing.
Nov 10, 2015 | Pioneer Televison & Video
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
I need CD ROM for the DCR- SR 200. Can the software be downloaded online? Thanks
Yes. Select the appropriate operating system from
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRSR200&LOC=3
Aug 02, 2010 | Sony (ACC-FH60) for DCR-SR 200, SR 300...
Picture Pixelates
You need more light in your scene. The camera will take a lower resolution picture, when the light is low. Blowing it up just accents the low resolution.
Dec 08, 2009 | Sony (ACC-FH60) for DCR-SR 200, SR 300...
Display is dark
no reset. if you think you can open it reseat all the ribbon cables going to the Lcd.
Jun 01, 2009 | Sony Handycam DCR-PC109 Mini DV Digital...
The Display on my DCRSR200 has gone away
Best way of solving this problem. I have this problem too and you can just get another lcd screen for it here: http://www.darntoothysam.com/products/Sony-DCR%252dSR200-Camcorder-OEM-LCD-Screen.html
Oct 16, 2008 | Sony (ACC-FH60) for DCR-SR 200, SR 300...
Sony Handycam  DCR-SR200 Camcorder Logo
613 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
