Question about Fuji FinePix S3000 Digital Camera
Replace small onboard memory battery on S304
When I remove my rechargeable batteries and replace with fully charged ones the camera's onboard battery will not retain date settings.  Can this be removed and replaced?
I believe it can be, I have mine disassembled, but I cannot figure out what type of battery it is.
Posted on Jan 31, 2008
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
When I push the power button, the lens cap comes out and on the screen is a very brief shot of what the camera is aimed at. The camera stays engaged for one second and the lens cap goes retreats back into...
Try to remove the rechargeable battery and use a battery of the same type but an alkaline like the energizer. Sometime rechargeable battery malfunctions that it seems fully charged but actually is not. If the camera continue to power on when you replace the battery it simply means that your problem is in the battery.
Nov 26, 2010 | Kodak EasyShare M1093 IS Digital Camera
Camera is locked up
I understand your issue as the camera shuts down automaticly Please follow the instructions: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).' 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 21, 2010 | Kodak EasyShare CX7525 Digital Camera
I can´t switch my camera on and i also can´t recharge the battry throw usb
The camera doesn't charge though the camera is on. It only charges when the camera is off. Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak V803 Digital Camera
It won't turn on it drop from me once and now it won't turn on
In order to clearly determine the fault the model of your KODAK camera is needed However I hope this will help: If your cam use AA batteries: Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. If your camera model requires the manufactures batteries: Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 03, 2010 | Kodak EasyShare One Digital Camera
Battery will not charge
The dock can only charge KODAK rechargeble batteries.
Jan 01, 2010 | Kodak EasyShare DX6440 Digital Camera
M863 on turning on immediately closes down. Battery replaced and fully recharged-still problems persists.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 21, 2009 | Kodak EasyShare C613 Digital Camera
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
Kodak Z700 not firing up
I have the same problem. Removing the memory card and then starting up seemed to fix it; the camera would then start up ok even with the card in.
Mar 08, 2008 | Kodak EasyShare Z700 Digital Camera
Battery Life
This is a typical problem with these cameras. The culprit is a failed onboard battery. The battery is for retaining the time and date while replacing the removable batteries. If you put batteries in and set the time and date- then remove the batteries for about 30 seconds- put the batteries back in- if it asks you to set the time and date again the onboard battery is no good. If you remove the onboard battery your camera will be very usable and the batteries will last 100 times longer. If you can change the batteries quickly you will not have to set the time and date because there is a small capacitor that will retain a charge, in other words it works better without the battery. I have done this to about 15 of these cameras and all worked great afterwards. You will need a precision philips screwdriver to remove the 7 screws that hold the case together. The onboard battery is small, like a hearing aid battery, mounted on the lower board just behind a piece of brownish cellophane like material. Just cut the material open and look in there between the boards and you will see it. It is mounted flat grap it with some precision long nose pliers or tweezers, wiggle it until the solder joints fail and remove it. Re-assemble and your paperweight is a camera again. If you do it wrong ,which is unlikely, you still have a functioning paperweight.
Dec 04, 2007 | HP Photosmart 635 Digital Camera
Fuji FinePix S3000 Digital Camera Logo
88 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
