Question about Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner
Cannot create process pmcloader.exe Installation Pinnacle PCTV DVB-T Stick Solo, on Windows XP SP3.Already was installed the Windows Net Framework 2.0, and other versions NF. Installation is finishing, yes but noting happens after this.I intalled the program from CD 2 times.No difference in result
I lost my installation disc for windows xp pro and I needs product key code?
Its illegal for anyone to provide serial keys for programs that have retail value set on them
If you are trying to recover a key of an already installed program on your computer there are freeware keyfinders on the internet
http://download.cnet.com/%7Bvalue=http://www.download.com/magical-jelly-bean-keyfinder/3000-18487_4-10079600.html The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry.
It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping.
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP.
While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so.
However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop.
Download ImgBurn and save it to your Desktop.
Double-click the installation executable for ImgBurn and click "Next."
Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn.
Insert a blank CD-R/DVD-R into your DVD drive.
Open ImgBurn by going to "Start," "Programs" and "ImgBurn."
Click "File," then "Browse for a source file."
Navigate to your Desktop and select the SP3 ISO file.
Click "Open."
Click the blue "ISO to CD" button located on the bottom left of ImgBurn.
The program will begin creating the Windows XP SP3 installation CD.
This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned.
Click "OK" once the CD-R/DVD-R has finished burning.
You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
XP PRO SP3 ISO
Download the iso also download the imageburn
http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/
The process "winlogon.exe" runs in the background.
Winlogon is a part of the Windows Login subsystem, and is necessary for user authorization and Windows activation checks. http://www.neuber.com/taskmanager/proces...
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager."
Microsoft designed Windows so many small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that runs on start-up, and its primary function is to monitor the use of other applications.
Winlogon.exe typically only runs for about a minute or two when Windows first boots up, so if for some reason it is still running five or 10 minutes later, it could be infected.
Spyware and other malware would infect this application because it can manipulate other programs in Windows, causing problems.
If this is the case, the file might need to be removed.
if you want to remove this from
Open "My Computer" and select the "C:" drive.
Double click the "Windows" folder, then select "System 32." Navigate through the System 32 folder until you find "Winlogon.exe."
Click the "Winlogon.exe" file and hit "Delete."
Select "Yes" when asked if you're sure you want to remove the program.
Oct 12, 2011 | Compaq Computers & Internet
Tip
How to Slipstream Drivers on Windows XP using WINNT.SIF
So you have already slipstreamed Service Pack 3 using one of the many tools available I prefer Autostreamer v1.0.33 Its Autopatchers little brother and takes the legwork out of uncompressing and recabbing. I then tend to integrate WMP11 using boooggy's slipstreamer this allow then installation of all associated WMP11 hotfixes.
When all this has been done its a good idea to slipstream all the post SP3 hotfixes to the I386 folder and also copy the WINNT.SIF file that you have created to perform an unattended install with drivers.inf files.
One of the best update packs available is Xables the latest version is v2.0.2 (August 2010) download link HERE this what the pack includes History at the point of posting August 2010 its stands at around 219 post SP3 hotfixes its only missing about 12 hotfixes mainly NET. Framework Service Pack fixes. Plus 12 optional updates you will need to go to the update website to get those if you really want them, or here is a list so you can google them
  1. Update for Windows XP (KB961118)
  2. Update to .NET Framework 3.5 Service Pack 1 for the .NET Framework Assistant 1.0 x86 (KB963707)
  3. Security Update for Jscript 5.8 for Windows XP (KB971961)
  4. Update for Windows XP (KB976662)
  5. Security Update for Windows XP (KB981332)
  6. Microsoft Browser Choice Screen Update for EEA Users of Windows XP (KB976002)
  7. Microsoft .NET Framework 3.5 SP1 Update for Windows Server 2003 and Windows XP x86 (KB982168)
  8. Microsoft .NET Framework 1.1 SP1 Security Update for Windows 2000 and Windows XP (KB979906)
  9. Microsoft .NET Framework 3.5 SP1 and .NET Framework 2.0 SP2 Security Update for Windows 2000, Windows Server 2003, and Windows XP x86 (KB979909)
  10. Microsoft .NET Framework 3.5 SP1 and .NET Framework 2.0 SP2 Update for Windows Server 2003 and Windows XP x86 (KB982524)
  11. Security Update for .NET Framework 2.0 SP2 and 3.5 SP1 on Windows Server 2003 and Windows XP x86 (KB983583)
  12. Cumulative Security Update for Internet Explorer 8 for Windows XP (KB2183461)
When you have installed this you are ready to copy your WINNT.SIF file to the I386 folder and create the drivers folder in your Windows Source Folder, then use Signets DriverGrabber v0.51b on your existing installation to get all the INF DLL and EXE files that you will need for your driver folders
Create an $OEM$ folder and place inside it a folder called $1 and then another inside that called Drivers then a folders for each driver make sure that you number then to ensure that chipset is always first.
001_chipset <-----this must be first
002_LAN
003_audio
004_display
005_monitor
006_modem
007_USB
008_ <------
more folders you need to add to the OemPNPDriverPaths
these are the paths that I have specified in the WINNT.SIF relevant section, you MUST add these lines in the [Unattended] section OR it will fail on you. !!!!
NOTE: The OemPnPDriversPath can't search sub-folders to all the files that Driver Grabber will give you will have to copied them to the relevant numbers root folders, and remove the subfolders for each driver remember that each path is separated by a semi-colon
DON'T
add an extra semi-colon at the end, it might fail !!!
OemPnPDriversPath=\Drivers\001_chipset\;\Drivers\002_LAN\;\Drivers\003_audio\;\Drivers\004_display_2003\;\Drivers\004_display_2004\;\Drivers\005_monitor\;\Drivers\006_modem\;\Drivers\007_USB\
DriverSigningPolicy=Ignore
NonDriverSigningPolicy=Ignore
UpdateInstalledDrivers = Yes <---- this line is critical to make sure
All you need to do to complete this process is change these two sections to suit your OEM Licence and Owner Details.
[GuiUnattended]
AdminPassword="" <------- this can be encrypted using sysprep
EncryptedAdminPassword=No
OEMSkipRegional=1
TimeZone=85
OemSkipWelcome=1
ProfilesDir="C:Documents and Settings" <------ you can change this
[UserData]
ProductKey=xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
FullName="your name"
OrgName="your organization"
ComputerName=your computer <----- note that there are no "." on this
FINAL NOTE: if you are using OOBE.INI in the either the $OEM$\$$\system32\oobe folder OR a cabbed (use Compression Bin by Jcarle) to create the OOBE.IN_ in the I386 folder, to set up new users (max 6 admins only) then make sure that you don't use these three lines in your WINNT.SIF to avoid any setup errors on the Out of Box Experience.
[Data]
AutomaticUpdates=yes
[Unattended Section]
AutoActivate = Yes
OR you will get a Out of Box Experience Error after the install as these skip the Create User Accounts and Set Up Internet Screens
If you have any other problems add these sections to your OOBE.IN_ and WINNT.SIF files that you have in your slipstreamed I386 folder
WINNT.SIF
[Unattended]
UnattendSwitch
= Yes
[Display]
AutoConfirm = 1
OOBE.IN_
StartupOptions]
Offline = 1
Registration = 1
ScreenResolutionCheck = 0
[Options]
IntroOnly = 0
NoIspPreconfig = 1
JoinDomain = 0
AdminPW = 0
SkipAutoUpdate = 1
[UserInfo]
Identity000="You"
remember to keep your OOBE.INI file so that you can edit it before you cab it with compression bin or makecab.
on Aug 22, 2010 | Microsoft Windows XP Home Edition
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Feb 23, 2010 | Office Equipment & Supplies
PCTV Dual DVB-T Diversity Stick does not work on my Windows 7 computer
it works ! go to pinnacle homepage and download the newest driver, works fine with windows 7 32 and 64bit.
(install just the drivers and use windows mediaplayer to watch tv)
Jan 19, 2010 | Pinnacle (210100320) Video Capture
Microsoft LifeCam 2.07 Set Up Taking HOURS!
In my case the LifeCam 2.07 installation problems on Win XP SP3 were related to Microsoft .NET Framework. Figured this out by looking into the temporary directories LifeCam installation creates - it seemed like it was repeatedly extracting and trying to install .NET 3.0 without success. Fixed this by installing .NET Framework 3.5 SP1 and all following updates from Windows Update first. Then the LifeCam installation worked fine.
Jul 01, 2009 | Microsoft LifeCam NX-6000 Webcam
Microsoft lifecam 2.07 installation problems - Infinite loop
Jun 20, 2009 | Microsoft LifeCam NX-6000 Webcam
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner Logo
1,486 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
