Question about Panasonic DMR-E85H DVD Recorder
///// SELF CHECK /////
I did try to replace some capacitors but the problem is still here.
My DMR-E85H is doing //// SELF CHECK //// and some time showing
hash "///// 1 //////" non-stop
  • kelvincalvin Aug 01, 2009
    STR-G6353 replaced and now display showing //// TEST *AV 1 ////
  • 158 Answers
REPLACE THE PSU REGULATOR- STR6353
Posted on Jul 27, 2009
  • Peter Sep 30, 2010
    Where to from here? I have the same problem - replaced the STR6353 which returns power to HDD, then stuck in ///Self Check///, initialised (open, skip, <<) and now have *AV1 test stuck on. I put another 80GB HDD from my PC in, however it does some seeking then shutdown. The old HDD appears to be still spinning. Any suggestions? (no bulging caps) Peter from OZ.
DMR-E95H doing self check for up to an hour
Your problem may be Panasonic's common capacitor failures. Open case and look for capacitors with bowed out top and yellow substance. Replace both with higher rated capacitors from Radio Shack. Will need some soldering skills. Look on this site for "solder c1260 c1261"
Sep 01, 2009 | Panasonic DMR-E85H DVD Recorder
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd video recorder dmr-e85h is dead
I had same problem. I replaced two bad capacitors on the power supply card. See http://vassfamily.net/projects/DMRE85H/dmre85h.html The capacitors I replaced were C1260 and C1261 slightly different from the one on "vassfamily.net". Everything works now for me...
Good luck.
Also for those interested, I found the "commands" listed on http://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h to correct problems.
Jul 26, 2009 | Panasonic DMR-E85H DVD Recorder
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
Try replacing bad capacitors on the power supplycard. See http://vassfamily.net/projects/DMRE85H/dmre85h.html
Good luck.
Alsofor those interested, I found the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h tocorrect problems.
Jul 24, 2009 | Panasonic DMR-E85H DVD Recorder
No lights or power indication at all on my DMR-85HP.
I had same problem - No Power/No Display. I replaced two bad capacitors on the power supply card. See http://vassfamily.net/projects/DMRE85H/dmre85h.html The capacitors I replaced were C1260 and C1261 slightly different from the one on "vassfamily.net". Everything works now for me...
If replacing the capacitors doesn't work, try replacing PSU Regulator - STRG6353.
Good luck.
Jul 02, 2009 | Panasonic DMR-E85H DVD Recorder
PANASONIC DVD RECORDER DMR-E85HP
Check caps on P/S C1270 and C1271 if puffy replace with {2} 1000uf 35vdc and you should be fine.
Jan 12, 2009 | Panasonic DMR-E85H DVD Recorder
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR E85H Shuts down when playing DVD or dubbing
the ic chip fixed mine tried to contact panasonic to give them negative feed back .its imposable
Mar 08, 2008 | Panasonic DMR-E85H DVD Recorder
Can I learn to replace the capacitors on my DMR-E85H
Try to reheat the power supply section.2nd what kind of capacitor is that is it polaryzed or non polar?
Mar 17, 2017 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
476 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
