Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Bosch fridge freezer - ice build up and water leak from freezer
Hi, hope someone can help me. i have a Bosch upright fridge freezer (not sure of model, about 3 years old) that has been faultless until recently. there has been an ice build up at the bottom of the freezer beneath the bottom drawer. the freezer has auto defrost so i don't know why this is still happening. the operating temp is set at -20. i also get a bit of water leaking from the freezer on the left hand side. my wife seems to think it is coming from the back of the freezer when you remove the drawer. any ideas, thanks
    Genius:
  • 1,036 Answers
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Posted on Sep 08, 2009
  • Kimberly Palmer
    Kimberly Palmer Aug 11, 2012
    Thanks for the clear, precise instructions! It was exactly our problem, and was an easy fix (besides finally getting the freezer cleaned out) and it worked like a charm. Thanks again for sharing your experience! Most grateful to find such an eacy fix.
    Problem Solver:
  • 19 Answers
Could be an air leak around the door seals. put a piece of paper between the door and the freezer if it slides around easly then the seal is leaking air and moisture into the freezer. Also -20 is extream. you could turn the temp up by 10 or 15 degrees and it may solve the problem and so money!
Posted on Jul 26, 2009
How do I get the plastic back panel off without breaking it to defrost the evaporator? Bosch No Frost fridge freezer icing up in top third of fridge
You unplug the refrigerator & let it melt &
work on cleaning up the water
If your getting too much ice build up, it could
be that you have a leak & lost refrigerant or
other system that heats things to prevent that
have failed
Have you turned down the thermostat to see if
that helps?
Aug 31, 2013 | Bosch Refrigerators
The fridge has stoped workingbut the freezer is fine
if it starts working ok after the defrost then you might find it will build up ice again.
There might be a fault with a small device called a thermister that senses the ice build up for the defrost controller.
What most likely is happening is the ice build up freezes the fan that blows the cold air to the fridge compartment.and around the freezer.
May 14, 2017 | Bosch KGU6655
Bosch upright freezer ice maker and water dispenser just stopped working
hello many times when the water and ice stop working you are not getting water to your freezer. so a few things to check if you have a water filter behind the freezer check for a blocked filter next. where the water line hooks up to the freezer there is usually a screen . turn the water off and remove the water line and check the screen if that s all ok it maybe the water solenoid hope this helps if not get back with me pls jason
Jun 09, 2010 | Bosch Freezer B24ID80SRS Stainless Steel
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Mar 14, 2009 | Bosch Refrigerators
Bosch stand alone freezer Intelligent 32 - how to defrost
Hi
I have the same refrigerator and found the manual;
"The refrigerator compartment was programmed to defrost automatically meaning you do not have to constantly clean and dry it. Copy from the manual"
Also have a look in the back for the drain outlet - very small. If that is clogged up it also cause water on the inside.
Feb 28, 2009 | Bosch KSR34464 Refrigerator
Bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Feb 10, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
6,021 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
