My Kawasaki 2003 Vulcan 800 classic has a fuel leak from the carburetor and every time that I put gas in the tank it starts leaking again what is the problem on this and how to solve it
More than likely you have a bad fuel petcock. No fuel should go from tank to carb without the engine running because the fuel is pulled by vacuum. Remove line from petcock an have it set to on or reserve position and if fuel comes out it is bad, and let's the fuel continue to flow to the carb and seep into the engine oil also. Mine was bad and had my oil thin as water with all the gas in it. Wonder it didn't wash a bearing out of the engine. Check and drain oil immediately if the petcock is bad.
SOURCE: remove a gas tank
there are 2 bolts at the front of the seat, takeoff the seat, unsrew the bolts. that is the only thing holding it on. push the tank forward a bit, then lift up. there are breather tubes under the tank. be careful, they are difficult to get back on depending on the length. there are 2 bolts at the front of the seat, takeoff the seat, unsrew the bolts. that is the only thing holding it on. push the tank forward a bit, then lift up. there are breather tubes under the tank. be careful, they are difficult to get back on depending on the length.
SOURCE: gas tank
I'm pretty sure it does. I own a 1995 Vulcan and I bought a 2003 tank and looked at the mounting brackets and fuel connections all looked to be the same - but don't put this in stone. I haven't been able to put it on yet because it's still out being painted. There should be no difference in the fuel tank mounts from 1996-1005, but as always, check with a professional if this information is critical.
SOURCE: no start
Make sue\re to add fresh gasoline to the fuel tank and make sure it is entering thr carb.
SOURCE: lifter adjustment
IF I recall correctly, the Kawasaki valves are adjusted by shims as opposed to a lock-down screw or hydraulic lifters. The shims come in different thicknesses. As the valve parts wear, a change in shims is how the valves are adjusted.
SOURCE: i just bought a 2004 vulcan classic 800 how do i
Try out the electrolysis way. please send me your email addy on [email protected] and i will send you the complete process wth illustration.
As for the fuel line, remove the line and blow it out wth high air -pressure.
