My KOLIN window type remote control AIRCON is building up ICE
WHEN I NOTICED THAT MY AIRCON WAS BUILDING UP SOME ICE, I HAD IT CLEANED AS IT IS ALREADY DUE, BY AN AUTHORIZED TECHNICIAN HOPING THAT THE PROBLEM WOULD BE SOLVED. HOWEVER, I FOUND OUT DAYS LATER, THAT ICE STILL BUILDS UP . THE AIRCON STILL COOLS UP MY ROOM,BUT NOT AS MUCH AS BEFORE. I WOULD KNOW THAT ICE IS BUILDING UP WHEN I COULD NOT FEEL THE BLOWER AS I GO NEAR THE AIRCON. I WOULD THEN PUT THE AIRCON TO FAN SETTING THUS MAKING THE TEMPERATURE RISE (HOT) CAUSING THE ICE TO MELT AND DROP. I WOULD THEN HEAR SOME CRANKING NOISE AS THE ICE POUNDS AGAINST THE SUCTIONING BLADE OF THE FAN MOTOR. THENAFTER,I WILL AGAIN PLACE THE SETTING TO COOL. THIS HAS BEEN GOING ON FOR ABOUT A MONTH AND FOR THE REASON THAT MY AIRCON STILL COOLS UP MY ROOM ,I HAVE NOT CONTACTED ANY AIRCON MECHANIC YET. PLEASE GIVE ME SOME TIPS AS TO THE POSSIBLE CAUSES OF THE PROBLEM THAT I MAY BE GUIDED IN FINDING THE SOLUTION BEFORE I HIRE A REPAIRMAN.THANK YOU AND MORE POWER.
JESS
    Guru:
  • 587 Answers
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Posted on Aug 25, 2009
It has a undercharge or lack of refrigerant.
Posted on Apr 17, 2013
2 Suggested Answers
  • 26 Answers
SOURCE: MY AIRCON IS BUILDING UP SOME ICE
Sounds like it's low on charge, dirty coil. Is this a ductless unit or window?
Posted on Jul 26, 2009
I am asking for the code of kolin tv for chunglap remote controler thank you.
0281,0288,0285. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 09, 2014 | Olevia Kolin DLT2711M 27 in. LCD...
P7 error on screen
Try to Replace the sensor/ evaporator.
Aug 28, 2013 | Heating & Cooling
I have a Universal Remote Control model huayu rm-68e+ and lost my manual and i need it for my kolin tv can anyone know the code for my Kolin TV in these universal remote brand tnx
If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Two digit, three digit, four digit and five digit setup code list to different models remote controls are given. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Check this link too. http://electrohelponline.blogspot.com/.
Don't mind about the brand name of remote control. Look for codes to your TV brand, whether it is 3 digit, 4 digit or 5 digit; whatisover.
May 02, 2013 | Televison & Video
How to set taiyo aircon remote to daikin aircon
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
Mar 23, 2013 | Televison & Video
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
My window type aircon compressor run for 5 min,then stop for 4min,then run again for only 5 min even if the thermostat is set to the coolest setting and the the room temperature is higher than 30deg.C.it...
I have the same problem w/my CW-XC122VU. Other symptom is that the thermostat setting does not work in this "poltergeist" mode. After the problem went away by itself, then re-occurred, I notice it tracks the level of the water in the pan. A full pan of water will trigger poltergeist-mode, so I suspect some control or sensor is being shorted. The posted solutions ("transformer hum" or "broken on/off switch" are off the mark and generally unhelpful). We are not alone, though...the problem is observed in many Panasonic and Quasar window A/C units.
May 18, 2010 | Panasonic Heating & Cooling
Jul 26, 2009 | LG Heating & Cooling
WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Blueway air conditioner not fully cooling
Check the radiator for dirt, and check if the radiator fan is functioning. Do you notice any wetness or ice build up on the outside copper pipes. If so, suggest calling a refrig. tech. to add gas. The gas used is R22 on most aircons.
Feb 02, 2009 | Heating & Cooling
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Heating & Cooling Logo
1,094 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
