Windows won't start up
Left on overnight ac plugged in,then i turn off in the morning but hanged on me.what i did is forced it to turn off.when i turn it back on blank screen with a little white dash line blinking only appears on the screen and only the battery and power icon is lit on led indicator.pls help
  • 746 Answers
Dear! there are three possibelities;
1. It might be possible your Ram has created problem so you should change their slot and if you are use two exchange their place.
2. It might be possible that your VGA cable has created faul so you can check it and pluged again.
3. It could be possible that your VGA card might create problem so if there is a problem you should change it.
Thank you
Posted on Jul 26, 2009
Bought new battery. morning vuka don't want to start. mornings I had to jump start it 0km still refuse to start on its own
Probably something draining the battery overnight. Interior light left on? The regulator in the alternator could be bad and keeping the ignition energized draining the battery. If your jump start it drive to work get off work and it starts after 8-9 hrs you have a system voltage leak some where. If nothing is left on overnight have the voltage regulator tested in the alternator.
Aug 13, 2017 | Cars & Trucks
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
Overhead console, AC, windows not working
check all fuses. in both boxes. some cars have 3 boxes
Jan 16, 2014 | 1999 Jeep Grand Cherokee
1990 Plymouth Voyager won't turn over
Last time my van did that it was the alternator failing to recharge the battery.
Sep 26, 2012 | 1990 Plymouth Voyager
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
I have a Th-50PC77U that doesn't turn on. Relays will click and start to power up but then it goes into safe mode and the power LED blinks 7 times. Is there a circuit board i can replace to fix this?
& blinks is sc or,sd or ,su board or all 3. Disconnect the ac cord. remove the back cover. on the left are 2 thin boards with flat cables that connect to the panel. these 2 boards are the SD and SU boards. They are connected to a board to the right. This the SC board or Y sustain board. Disconnect the 2 wie plug that connects this SC board to the power board in the middle. Examine the sqauare ics on the SC and SU boards on the rt side. Look for a pit or burn mark on one of the ics. If you see one then this board is bad. Disconnect this board from the SC board remove connectors on the rt and also remove the all the screws on this board. It should now be hanging free only by the flat cables on the rt. reconnect the 2 wire cable from the SC board to the power board. Plug in the set and power on. If set turns on the that board needs replaced. You will see 1/2 of picture. If still won,t turn on then disconnect the ac cord and the 2 wire conn from power board to SC board. disconnect the other board on the left letting it hang free. re connect SC to power board,plug ac cord in and turn on. If set now will turn on then Replace that board. If stiil won/t turn replace the SC board.
Sep 08, 2011 | Panasonic TH-50PX77U 50 in. Plasma HDTV
My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Just try this and leave a feedback for next steps.
Jun 16, 2011 | Dell Computers & Internet
M465-E will not turn on
Simply your RAM or mother board is faulty. Replacing RAM is cheap but repairing Mother board modules is an expensive affair.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Gateway M465-E Notebook
Zune Hanging
It's a glitch with Microsoft. All 30 gig units are affected. It's a leap year and the extra day threw the software. Let it discharge overnight and plug into your computer in the morning to load. Microsoft is supposed to have a fix.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
