Question about Sony PlayStation Portable (PSP) Console
Broken inner screen, yellow and blue lines only, but audio working
    Guru:
  • 111 Answers
It sounds like the LCD needs replacing.
You can purchase the parts yourself at http://parts.consolerepairguy.com which is where I get all of my parts (I fix consoles)
Posted on Jan 27, 2010
Color lines running down the screen
That can be caused by either the Tcon or the panel itself may have an issue. The TCon is most likely though. Your audio works correct right? I would try a new TCon you can get them from www.tvrepairworld.com
Jan 11, 2013 | Sharp LC32D62U 32 in. LCD HDTV
Have a 52 inch flat screen, formed vertyical lines,of blue red green yellow orange, white, pink ,and purple.
When and why did this occur, also make and model number are needed to clarify possible causes however it sounds like it's broken beyond economical repair
Apr 06, 2012 | Cars & Trucks
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Both screens of my EnV2 are blank but phone works
i am having the same exact problem HELPPP ! i need my pictures and contacts
Nov 09, 2008 | LG enV VX9900 Cellular Phone
Picture problem Model Toshiba 61H71
Hi, convergence circuit has failed, IC`s and probably 1 or 2 precision resistors will have to be changed, not really something you can fix if your not an electronics tech, BMW Rider
Jan 09, 2008 | Toshiba 61H71 61" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
4 wheel dive problems.
For the older wranglers using the vacuum system to engage and disengage 4wd, check this out. You should have red, yellow, green, and blue vacuum hoses coming from the transfer case. The red line ends in a check valve so when you do maintenance you can make sure you have vacuum. The yellow line runs to the middle port on the Command-Trac motor. It T's off and runs to a check valve that T's into a black vacuum line. The green line runs to the port on the outside of the Command-Trac motor. The blue line runs to an air vent filter. The black line runs from the inner most port on the Command-Trac motor to the 4wd indicator light and switch. Along the way it's T'd into by the yellow line I was talking about earlier. Hope that helps
Dec 10, 2007 | Jeep AM/FM Cassette with CD Changer...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Sony PlayStation Portable (PSP) Console Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
