Question about Norcent Technologies LM730 17" Flat Panel LCD Monitor
Monitor shuts off after initial start-up
17" Monitor shuts off after a few seconds on initial normal startup. Sometimes it will stay on but mostly shuts off. Is this an auto shut-off due to wrong high voltage readings? What will it take to fix, parts or adjustments? Same Problem on different PC's and my laptop!
  • 4 Answers
Re: Monitor shuts off after initial start-up
My 17 inch Norcent LCD was doing the same thing. Then after a couple of weeks the AC adapter failed. I got a new ac adapter now LCD is working.
Posted on Dec 29, 2008
0 characters
3 Points
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Monitor stays on for a few seconds then goes black
could be your wires or your moniter itself check those replace the wires and see what happens if it doesnt work just pm me
Feb 26, 2012 | Dell E173FP 17" LCD Monitor
Screen comes on during startup for only a second or two, then display shuts off, not the power light. if i try to power it down then back up it doe the same thing. so i figured its a capacitor so im trying...
That issue is normally caused by the backlight in the LCD. The compact florescent light in the display is burning out. They will normally light for a few seconds when first powered on, then shutoff.
Ultimately, the bulb needs to be replaced. If your into hacking electronics, you can get a replacement bulb online and DIY. Otherwise, the cost of having it repaired is usually very close if not more than a new monitor.
Dec 05, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check or
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Hp pavilion f1703 problem
Burned out backlight fluorescent backlight.
Jan 04, 2009 | HP Pavilion F1703 17" LCD Monitor
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
Norcent Technologies LM730 17" Flat Panel LCD Monitor Logo
518 people viewed this question
Top Norcent Technologies Computer Monitors Experts
Carl Glas
Carl Glas
Ted Rishel
Level 1 Expert
Are you a Norcent Technologies Computer Monitor Expert? Answer questions, earn points and help others
