SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: how to zero the chrono second hand( doesn't reset to zero)
Paste this link into your browser, find your movement caliber number and download instructions how to reset your Citizen watch:
http://www.citizenwatch.com/COA/English/settings.asp
Do not forget to rate, please.
SOURCE: Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
SOURCE: Second hand does not return to zero caliber 3606
Yes, this can be recalibrated from the outside. To get your chrono hands pointing in the right direction pull the crown out to the first position then click the plunger/ chrono button. This should move your chrono hand one click at a time to get it to the right place. If this does not work try pulling the crown out to 2nd position (all the way out) and try clicking the plunger as described above.
If this STILL does not work, which it should, then you'll need to go to an Omega dealer and have them take a look at it.
SOURCE: chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
