I assume that you are referring to the wheel studs and if so you will have to remove the wheel, the brake caliper, the brake caliper stand and the brake rotor. Drive the old stud out with a hammer. Make sure you purchase new lug nuts with the studs. If they are the acorn style, buy one that is not to help with installation. Slide the new stud in the hole from the rear of the flange, install some washers for clearance of the stud shoulder. Install the non acorn style lug nut on the stud backwards. Using a impact gun, pull the stud through. Remove the backwards lug nut and washers.
broken studs on the tire. cant get the hub off, do I need to remove the axle?
Broken studs to what ? The tire, the exhuast ?
