Question about Microwave Ovens
It's a Kenmore 85410. The microwave won't go off. Cooking ends, the light goes off, the turntable stops, but the microwave continues. It will stop when I open the door. It also appears that it won't cook at anything but the highest power. But there's just a constant humming and the oven gets hot unless I unplug (which I have) or open the door.
  • peipete Jul 26, 2009
    thanks for replying... the fan does go off normally when timer keypad is used... does that it mean it's more likely in the control panel that the wiring has to be replaced??
    thanks for your help
  • Microwave Ovens Master
  • 19,396 Answers
If magnetron (source of heating MW) or fan are not turning off, that means that there is a contact, either in magnetron connectors, or on control board connectors, or that the control board is faulty.
If the contact to magnetron and fan is closing when you open the door then it is more likely a contact in control board connector.
The problem is fixed replacing the wiring harness connected to control board, and/or the keypad/timer assembly.
Magnetron and capacitors inside the MW can release electricity even when the appliance is not connected to power. For safety reasons the microwave oven must be tested for energy leakage after repair.
You can find parts here.
Try also here.
Also parts here.
Regards.
G.
Posted on Jul 26, 2009
  • Ginko
    Ginko Jul 26, 2009
    That may suggest that the problem is control panel or keypad. Sometimes, depending on the model, this two parts are separate, in that case better replacing the keypad first.
MY stop/clear button doesn't stop all the time.
It may be making noise, and the light comes on, and the turntable goes around, but I'll bet it's not actually cooking (although that CAN happen). Try putting a cup of water in the microwave when this happens and see if it gets warm. If it does NOT get warm, then you just have a bad door switch. If it DOES get warm, then you have a stuck relay on the control board, and the control board will have to be replaced.
Oct 15, 2014 | Microwave Ovens
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Light goes out and turntable stops, but still hums like power is still on.
You have a bad door switch that will need to be replaced.
May 13, 2012 | LG Microwave Ovens
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
My built in microwave stopped cooking. The light & turntable continue to work however. Help?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jun 07, 2011 | Kenmore 62622 Microwave Oven
The other day my microwave quit cooking and the turntable stopped turning. The fan still turns on and the light still works as if it is cooking but it doesn't. We shut off the power and tried again but it...
It may just be a bad door switch. See this file.
You can enter your full model number at the Sears parts site to find helpful exploded view diagrams.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
May 27, 2010 | Kenmore 62622 Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Whirlpool microwave only cooks for limited time?
It's possible that the module that produces the microwaves is failing. The parts are cheaper but the labor may not so get an estimate before deciding if it's worth repairing or replacing.
Nov 20, 2017 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
316 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
