Question about Epson Stylus Pro 10000CF InkJet Printer
Hello i have a service light on saying print head tempreture,would i need a new print head ,please help thanks
  • 42 Answers
this service message just warns you that the print head temperature is not normal. just give it some time to get to room temperature and then continue printing. if the problem persists, try troubleshooting the printer or test print to check the condition of the printer.
cheers
Posted on Jul 26, 2009
My HP 6500 wont print black ink. It's like a very very light grey and I can't see it. Tried 2 new print cartridges and no luck. Please help.
The HP 6500 printer has separate in cart and print heads. The light print you are getting is because the print head in clogged with dry ink. First thing to try is to go into the printer software on your computer and do a print head cleaning procedure, this will take a few minutes to finish. You may have to run this several times to clear out the dry ink. If this does not solve the problem when you will need to get a replacement print head, the part number is CB868-30002
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
Hello, my canon ip4000 just won't print properly. i have been executing "deep cleaning" numerous times but the print out still has missing lines. i sent it to our local canon service center...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 24, 2011 | Office Equipment & Supplies
Head printer error
Print head error is what you saying?
This mean your print head needs to be cleaned or replaced. you need go go out and purchase a new print head or try and clean the one you have.
you can try this tip:
http://www.hardwaresecrets.com/article/178
or simply call epson for a new print head.
thanks hope this does help please do rate and leave feedback for your free answer today.
Apr 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Office Equipment & Supplies
1995 isuzu trooper manual transmission is leaking fluid from the gear box bolt. i was wondering if this is motor oil or is there transmission fluid somewhere i need to fill or check?
Hello smeet3992: The transmission uses 5w-30 for tempretures up to 95 degreese in tempreture. Uses 15w-40 for all tempretures greater then 50 degreese. If you are in an area that has extreme fluctuation in tempretures I would use the 15w-4o engine oil. I also senrt a picture of where to check the oil at. Make sure you pull the right plug. The reverse idler pin has the same size bolt head.
Please rate the quality of your answer as this helps to ensure you recieved the information you asked for. Thank You for using FixYa. Roger358a4b4.jpg
Apr 24, 2009 | 1995 Isuzu Trooper
CANNON MILTIPASS MP390
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer and this will solve yore problem definitely, you can get this print head from any Authorized Canon Care Centers, if you do not get it there you can revert me back.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Print Head install
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon PIXMA MP470 All-in-One Printer
Epson Stylus Pro 10000CF InkJet Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
