Question about Ducane Grilling
How to fix ducane burner - Ducane Grilling
    Novelist:
  • 170 Answers
How to replace burners
Replacing the burners on any Ducane Gas Grill is not an easy task. As the control panel has to be dismantled to accomplish it. With that in mind, I have included a link to the Owner's Manual. The section Annual Maintenance starting on page 21, will be a big help to yo in removing the old burners and installing the new ones.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
Hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Aug 02, 2011 | Ducane 30400040 Stainless Steel Grill
The burners do not light consistenly. I can see the igniter spark and the fuel supply is good. If the igniter does work the main burners may not light until I creat a draft then the burner takes off.
It sounds as if, the burners need to be removed and thoroughly cleaned. As do the Venturi valves on the open end of each burner. Spiders like to build nests in the Venturi openings and clog them up. It's a prat of Routine Maintenance, takes a little time to perform, but is not difficult to do. It does require removing the burner knobs and the control panel cover (which was a poor design by Ducane/Weber)
To help make this a little easier for you, I have included a link to a Ducane Stainless Steel Model Grill that will show you how to remove the burners. Pay particular attention to the Annual Maintenance section starting on page 21. You can download and print this manual for future reference.
Hope this helps you. Please let me know and Happy Grilling!!
May 25, 2011 | Ducane 30400040 Stainless Steel Grill
Burner Replacement , How to disassemble.
Unfortunately, Ducane is the only grill manufacturer who requires the removal of the front control panel, to replace the burner(s).
Here is a link to the Meridian Series grills. Click on the link that is your model and you can download and print the owners Manual. In it under Maintenance, it will describe and show you how to remove and replace the burner(s).
http://www.ducane.com/manuals/
Hope this gets you back up and grilling.
Apr 29, 2011 | Ducane Meridian 30557501 Propane Grill
How to replace bbq tube burner for ducane grill
You can dowload a manual for your gill from the ducane web stire. Pictures and instructions are in the Annual maintenance cleaning section. You will need Adobe Reader to view thw dowload. Web site: http://www.ducane.com/manuals/
They have Meridian and Stainless models in 3 & 5 burner for LP & NG.
Apr 16, 2010 | Ducane 30400042 (LP)
How to change burners for a ducane meridian 32 inch 5 burner gas grill
Go to Ducane web site http://www.ducane.com/manuals/ and download the manual for your model.
Has Mederian 3 & 5 burners and LP & NG
Also has Stainless 3 & 5 and LP & NG
Need Adobe Acrobate reader that can also be downloaded.
Manual shows step by step in Annual Cleaning section
azrsanford@comcast.net
Apr 04, 2010 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Ducane F7011013 FireLight II grill I am looking for a replacement burner. The one I have has rusted out. Any suggestions on where I can get one? Is there another burner that will fit in this grill? ...
I have a brand new Ducane Firelight II Camp Stove/Grill in need of a regulator/hose assembly. Would you be interested is selling me the parts from your stove? kpirish810@yahoo.com
Apr 25, 2009 | Ducane F7011013
Meridian 5 burner trouble
Yes you can fix it. Carefully remove the screws that hold the panel where the burner knobs are, There are 3 screws on each panel under the side shelf. There is another screw up underneath the face plate as well. Once the screws are out pull the face plate up and out so that all the tubes are disengaged. It should rest about 2 inches tilted back. Now remove the grates and burner covers and inspect the burner tubes. You will most likely find that spider webs or hornets have blocked off the gas flow to the burner. carefully clean every burner tube out and put everything back. You also may want to use a bit of sandpaper on the ignitor tip. Put everything back together and you should be good to go. It seems all Ducanes attract spiders on the burners...
Apr 06, 2009 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Ducane high efficiency propane furnace, pressure switch problem
A short cycle heat cycle indicat a pressure switch replacement was needed. This did not fix the problem. the problem was in PCV line since the end was filled with slugs and cause the line to backup with water. When this happen the system would stop asking for gas. the water would leak out and it would restart. The problem was fixed by cleaning value at end of PCV. This released the water, two quart of water, that was back up causing problem. Curious if a filter change indicator was providing a clue that was missed?
Jan 28, 2009 | Ducane 436 inch 2 - 2 burner Grill
Grilling Logo
260 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
