Question about Dell Inspiron 1420 Notebook
Cannot run application (*.exe)
I cannot run any application, each time I open an application (.exe) a window appears telling me that "this is not a valid win32 application"
I tried opening my computer and the went to "tools", "folder options" and then in the "file types" section changed the file association for *.exe to application (%1) in the "registered file types" section but it still wont work. Then I tried changing the *.exe association to open with regedit32.exe just to see the difference and when I tried to open an application a window opened up saying "Would you like to add file.reg to the registry?"Yes"No". So I change the *.exe association back to application(%1) and then tried again but the the same window showed up.I still can't run any application.
My computer is Winxp PRO SP1
I have an updated antivirus scanner but it doesn't work since I had this problem.
Could you please help me get my computer back to normal again?
  • Anonymous Mar 22, 2014
    Already tried resetting it and still the same. Lost the application files for the games and everything else. Also can I connect to internet through wifi - broadband??
  • Dell Master
  • 32,281 Answers
Often this error message will be similar to the below error message.
C:Program Filesmyprogramprogram.exe is not a valid Win32 application.
Cause: This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Posted on Jul 26, 2009
  • Chris Hingee
    Chris Hingee Jul 26, 2009
    I forgot to mention.
    The latest service pack for XP is SP3.
    I suggest you install it, try to get a copy on CD, because it is approx. 350Mb in size and it wouls take a while to download.
  • 82 Answers
What is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Wat is winlogon that appear in my desktop
The process "winlogon.exe" runs in the background.
Winlogon is a part of the Windows Login subsystem, and is necessary for user authorization and Windows activation checks. http://www.neuber.com/taskmanager/proces...
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager."
Microsoft designed Windows so many small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that runs on start-up, and its primary function is to monitor the use of other applications.
Winlogon.exe typically only runs for about a minute or two when Windows first boots up, so if for some reason it is still running five or 10 minutes later, it could be infected.
Spyware and other malware would infect this application because it can manipulate other programs in Windows, causing problems.
If this is the case, the file might need to be removed.
if you want to remove this from
Open "My Computer" and select the "C:" drive.
Double click the "Windows" folder, then select "System 32." Navigate through the System 32 folder until you find "Winlogon.exe."
Click the "Winlogon.exe" file and hit "Delete." Select "Yes" when asked if you're sure you want to remove the program.
hope this helps
Sep 17, 2012 | Microsoft Windows XP Professional for PC
Tip
Alternate method to access Application Recovery/Recovery Manager in HP PC
Scenario: Recovery manager or Application Recovery on your HP Desktop PC doesn't work or you are unable to access Application Recovery or Recovery manager.
Tip:
For Application Recovery:
1. Click start, my computer.
2. Open C: and Windows Folder.
3. Open SMINST folder within Windows folder.
4. Double click appinst.exe to open application recovery.
For Recovery Manager:
4. Double click restore7.exe to open Recovery Manager.
If above folder is not found. Then,
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
on Jan 18, 2010 | Computers & Internet
My windows 7601 is not genuine appear on my windows. How can i remove it?
Dec 03, 2011 | Compaq Computers & Internet
In the process of installation of the disk #1 the following message appears: cannot open input source current file: DSSAGENT.EXE Thank you for your prompt help
As this could be spyware, try to run the http://live.sysinternals.com/ and run the procexp.exe to see a more detailed task manager...
dssagent.exe is a virus, trojan, spyware, adware which you can remove, or a file belonging to a Windows system or an application you can trust.
ssagent.exe is located in a subfolder of C:\Windows. Known file sizes on Windows XP are 546,304 bytes (72% of all occurrence), 590,336 bytes, 69,162 bytes, 510,976 bytes.
File dssagent.exe is not a Windows core file. Program starts when Windows starts (see Registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run). The program has no visible window. It is located in the Windows folder, but it is not a Windows core file.
Mar 28, 2010 | The Learning Company Learn to Speak...
Cmd.exe application error
Check out the below link to know the error -
http://hubpages.com/hub/cmd-exe-application-error
post further comment for more help..
Good Luck!!
Thanks
Jul 19, 2009 | Acer Computers & Internet
Explorer.exe - application error
Try the following to gather additional information.
Run a test on the hard drive(s) for any bad sectors via chkdsk
Run a memtest to verify the integrity of the physical memory. I would suggest the memtest via the Knoppix CD.
Look in the Windows Event Viewer, Application and System log for any possible resource contention issues or other system problems.
Dec 13, 2008 | HP Compaq ProLiant ML530 Server
Windows explorer has stopped working
Well if it continues to crash then theres a bigger problem
but a way to make it recover if the EXPLORER.EXE crashes is to hit
CTRL+ALT+Del
File
New task
Then type Explorer.exe and it should reload itsself and be back to normal
i also suggest running a scan with Ad Aware 2008 just in case wat u downloaded could by spyware
Oct 18, 2008 | Computers & Internet
System says that program not responding
From what you put on this, it seems that you have a KERNAL32 error.
Fault Module Name: kernel32.dll
the application being Windows Media Player
Application Name: wmplayer.exe
I've researched this thru microsoft and the best thing I can find
Go to Start - > Type Run in the Search Box - > type regsvr32wmp.dll
What operating system are you using? Because the KERNEL32.DLL file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (ME).
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
593 people viewed this question
Alun Cox
