Question about Samsung Televison & Video
Picture fine no sound at all,on screen says connect speaker. Have tried connecting speaker at back no result.Internal speakers are connected. Thanks Russell
  • 170 Answers
In the menu option, check that you didn't select to use external speakers.
Posted on Jul 26, 2009
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
The center speaker has no sounds, we do test the speaker and its working fine to other connections like to the front speaker.. i think that the connection to the avr (center) is the problem.. can you...
sounds as if the preamp our main amp is out on cener speaker. more then likely will need be sent in to be repair as there is more then one thing will need be replace to get it to work.
its unlikey the connections are bad would try to move them will unit is one see if u get any sound out them if not more of a internal problem
Feb 26, 2011 | Harman Kardon AVR 230 Receiver
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
I am unable to get the speakers to work at all. They will not play system sounds or anything. Troubleshooter suggested that I uninstall and reinstall the speakers. So I uninstalled and went to reinstall...
I don't know what is the operating system you are using with your computer.Still we can check, first we need to find out if the problem is with the speaker or with the computer.
Try these steps
  • connect those speakers with other computer check the sound, if you are getting sound there it means speakers are ok need to check computer audio setup and hardware.
  • If you are not getting any sound connecting speakers with other computer then it is speakers need to replace.
Incase speakers are ok Disconnect the speakers
  • restart the computer,check if there is windows sound if not
  • right click on the volume control icon on the left hand button corner of the screen,uncheck the mute option.still not getting any sound?
  • try to download the audio driver from the dell support site.still not getting
  • need to check the internal speaker connection,if it is fine
  • go to this website http://www.kellys-korner-xp.com/xp_tweaks.htm and click on Restore sound -windows Audio service and run the tweak,YOU NEED TO USE INTERNET EXPLORER
  • still you cannot hear the sound change the internal speaker.
Sep 26, 2010 | Dell A215 Computer Speakers
PT4231 have picture no sound, Selection is on internal speakers.
you can go to your menu and select the test tone just to see if your speakers are operational, if not replace the speaker. If you have test tone, then check your input connections. If everything is connected correctly then you need to replace your main board and that should resolve the problem.
Jun 22, 2009 | Norcent Technologies PT420 42 in. HDTV...
Speakers
If I understand you right, you have 7 speakers on 7 different channels.
When you have just 1 speaker connected it sounds fine, but any time you add more speakers it shuts down, or does it sound fine until you have all 7 of the speakers connected.
Bare with me, and we will figure this out. It is a very diificult job trying to troubleshoot something that is not in front of you.
After this post, it will be about an hour or so before you will hear from me again, I will be on my way home from work.
Is this a 5.1 surround system or is it listed as 7.1?
Do have have any speaker outputs with more than 1 speaker connected to it.
If this is a 5.1 system, do you have speakers connected to the "A and "B" speaker jacks?
What kind of speakers are they, and do they say on the back where you connect the speaker wire what ohm rating they are. Most speakers for your home are 8 ohms.
in case you were wondering what a 5.1 and a 7.1 system is:
the 5.1 system has front right, front left, center, rear right, rear left and the .1 is for the sub-woofer that is normally a RCA jack output on the back of the receiver
The 7.1 has all those same speaker outputs plus it has a surround back with right and left channel.
I will get back to you in about an hour or so.
Jun 23, 2008 | Audio Players & Recorders
Internal Monitor speakers
Have you plugged its connection to your sound card on the pc? Check the connection again. it will help you.
Dec 12, 2007 | Dell Powered Subwoofer Set A425 Computer...
Televison & Video Logo
60 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
