Question about Electrolux 23 in. ESI602X Built-in Dishwasher
Electrolux ESI 602 will not fill with water
We have a electrolux esi 602 that will not fill with water just makes a buzzing noise. i have looked at other problems but not sure where the float or water valves are??? can anyone help
thanks
  • 74 Answers
The float better be inside the tub, at the bottom, it usually only travels a couple of inches up and down... you may have a protective cover in the way of it.
Posted on Feb 22, 2010
Electrolux esi 6104 cycle not finishing and not heating up
Good Morning Ryan,
I understand that you are having trouble with your Electrolux dishwasher, model# ESI 6104, not finishing the cycle and not heating up. I will be more than happy to assist you. From the model number provided, I show that this was made in the UK. I have done some research and have been able to find the UK Electrolux telephone number. If you call 08445 613 613, they will be able to better assist you in why your Electrolux dishwasher is not finishing the cycle and not heating up. Hope this is helpful.
-Best Regards-
WP
May 11, 2014 | Dishwashers
Electrolux ESI 6180
I was shown how to clear your dishwasher and keep it running much longer. however, be careful when doing this. start with an empty dishwasher. pour 12 cups of cold water to the bottom area of tub and wearing latex, or rubber gloves, measre and por in exackly 2 cups of ammonia. let that solution sit there either all day, or overnight, at least a few hours, then run it through your machine, do not add anything else. do not do this with small children around. if you prefer buy the largest jug od vinegar (white) and pour it full strength into tub of your macine. let stand sevral hours, then put through a light or regulsr cycle. if you encountet that same problem empty, press drain cycle. retry usingrinse cycle instead. let me know if his resolnves your problem.
Nov 15, 2013 | Electrolux Dishwashers
Electrolux dishwasher ESI 602W leaking
Hello - From what you are describing the leak could possibly be coming from the drain motor/pump, loose hose connection or the door seal could be severely damaged. Contact a professional to accurately pinpoint any potentially more serious issue(s) and to properly assist with the repairs.
Jan 29, 2013 | Electrolux Dishwashers
Esi 68850 antiflood system has been activated
This means a water leak has occured into the base of the dishwasher where the pumps and motors are located. The system shuts off to prevent water damage to components and also prevent an electric safety hazard. The best solution is to find the source of leak and fix it. Ensure dishwasher water is turned off and the power is turned off at mains socket before you work on it.
check door seals and pump hoses for damage or wear and replace. If everything seems ok, then take out dishwasher from under kitchen bench aqnd shake it a few times on its base so that any water in the flood switch can dry out. Reconnect and check.
Jan 02, 2013 | Electrolux Dishwashers
The dishwasher is not filling with water and it makes a contant buzzing noise
Whenthe dishwasher is not filling, it is your water value not opening up on thedishwasher. The constant buzzing noiseyou hear is the value that is sticking not letting the water into thedishwasher.
May 11, 2011 | Electrolux Dishwashers
ESI 602 dishwasher trips out the mains trip switch after a couple of seconds after turning on any solutions please.
needs looking at.........bad earth can cause trip
also the rear element or stats wire can short against the machine casing.......
cheers
Mar 27, 2011 | Electrolux 23 in. ESI602 Free-standing...
I have an Electrolux ESI 6104x. Regularly just after starting the dishwasher as it starts to fill for the first time the water inlet cuts out. If you turn the water off at the mains disconnect the inlet...
Disconnect the fill pipe from the back of the machine and you should see a small mesh strainer in side the dishwashers inlet valve. Check that this is not dirty - to clean it pull out the strainer and rinse under the tap.
Dec 29, 2010 | Dishwashers
My buitl in electrolux ES1 602 wont fill just makes a buzzing noise Thanks Kath
Check for your solenoid, or make sure the water is turned on to the machine.
Feb 22, 2010 | Electrolux 23 in. ESI602X Built-in...
Open Questions:
Electrolux 23 in. ESI602X Built-in Dishwasher Logo
731 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
