Tv Keeps on changing input.
I had this TV for over 3 months now no problems at all until the past 2 days. When I have it on H.D.M.I it changes back to Cable, then the channels start changing. I took out the batteries from the remote, I thought it was jammed or stuck but that isn't the problem. The side panel is in top condition. I can't enjoy a movie, or a game, the TV keeps changing inputs on me. Gets really annoying. I leave it unplugged for a few hours come back it stays on H D M I for a half hour they it starts changing again I keep on going back, and fort but it just wants to go back to the cable. I need a solution before I bring out the bat.. >:|
  • 35 Answers
Remove the fuse and test it,if its burnt replace it with the same rating.
Posted on Jul 26, 2009
Tv guide doesn't work anymore
I have a Sony model KDL-32BXR6 that the TV Guide first showed no listings this past weekend. Last night when I entered the Guide the screen displaying the Setup/Display Setup Progress came up stating "In Progress". Same thing this morning. Something must have changes with the input signal if this occurred with two different sets.
Dec 04, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
TV says no signal from direct tv box
Yes, something could have gotten changed.
Confirm what input connection the DirecTV receiver is connected to on the back of the TV. Using the remote, check that the TV has that input selected.
Dec 16, 2009 | Televison & Video
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
Black screen when trying to adjust settings
Double check to be sure the TV is on the proper input.
Can you still play a DVD? If DVDs still play, reset the system by unplugging the power cord for a minute. The menus should return.
If DVDs don't play either you may have accidentally changed a video setting. Fortunately you can access the video settings from series II and III systems with the buttons on top of the console. If would be best to call Bose tech support so they can walk you though accessing the video settings. 800-367-4008
Sep 17, 2008 | Bose 3 2 1 GSX System
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Video Mode - Orion 27" TV - Model stv2555A
VICTORY! Had the same problem with my Orion model FTDV2004. Lost the remote and couldn't program a universal remote to change the input to AV. After a day of reading posts, I just started pushing the channel up button. Somewhere past channel 115 the "Line1" and "Line 2" inputs showed up.
Sep 26, 2007 | Televison & Video
Sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Oct 28, 2006 | Sharp 32F540 32" TV
Televison & Video Logo
603 people viewed this question
Top Televison & Video Experts
Electro Med Services...
