Question about Brother IntelliFax-2820 Laser Fax
Send fax from memory
Can't find instructions to send a fax from the stored memory. I know which memory job number to send but am stuck there.
any help out there?
thanks dave
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Fax memory full lexmark x
Memory full, cannot send faxes
The printer fax memory is full. Press the check mark button to clear the message and cancel the fax.
• Reduce the fax resolution and try to send the fax again.
• Reduce the number of pages in the fax and try to send the fax again.
Jul 09, 2014 | Lexmark X364dn All-In-One Laser Printer
Ran out of toner a week ago...stopped printing....did my print jobs and/or faxes go somewhere to retrieve later when toner replaced?
Your print jobs may still be in the spooler of the printer. Check the computer (Windows 7, Start > Devices and Printers. Windows XP, the title was Printers (IIRC)). The incoming faxes will be stored in memory; it can store up to 320 pages. (If you have other faxes in memory, the number of incoming faxes that can be stored will be less. Clear the memory after replacing the toner and printing the stored jobs. Press Menu until you see Maintenance then the left and right arrow to select the item to clear. Then press Enter to clear that area. When done, press Clear/Stop.)
I hope this helps.
May 17, 2010 | Ricoh AC205 All-In-One Laser Printer
Can't fax multible pages
Your fax machine reads multiple pages into memory before sending the job, this is the pool memory. Two things can cause this error.
  1. Corrupted memory, which keeps the job from transmitting because the data stored is scrambled and lost prior to transmission.
  2. Line static, which makes the connection so unstable and slow that the fax can't get enough pages out of the queue fast enough to make room for the next pages entering the buffer.
If you checked the line and it tested good (not just listening for a dial tone), then it is probably a memory issue.
May 06, 2010 | Brother MFC 420CN All-In-One InkJet...
It sounds like you have some bad jobs stuck inside the fax's memory. First print out a memory reference report. It will show you any bad jobs stuck in the system. Delete the memory reference jobs. Then go into set up and you want to turn off the option to store failed transmisions.
The system should store jobs while it is waiting for paper. If you have a lot of stored jobs and the memory is full it will not receive any more jobs until it can print out what is stored - so it would be normal for it not to recieve new jobs until all of the old jobs are printed.
Dec 24, 2009 | Canon FAXPHONE L80 Laser
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
Load your document on the scanner
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Go into the printer settings on the computer and change it from-send dirrectly to printer - to - Spooling. It will send a small portion of the print job at a time there for the printer mempry will not overload and report out of memory. Please rate this help if it works for you. Thanks!
Jan 28, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
down on the scanner glass.
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Storing Outbound Faxes not sending.
if you print a tx journal does it have an error on those you tried to send
Mar 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
224 people viewed this question
James Cagle
James Cagle
Jim Keysor
