Washer hotpoint not filling with water
  • 42 Answers
there could be many reasons for this, try these
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. if this develops crack or is deformed, you may develop a leak or blockage.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. there could be blockage or deformation in this tube.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. there could be some blockage in this.
try to find the place till which the water flow is unhindered in the machine.
cheers
Posted on Jul 26, 2009
Could you please tell me what h2o means on my hotpoint aquarius washer
Hi
H20 on these washers is a filling problem.
What you need to do is make sure the water supply tap is turned on the hose at the back isnt kinked up.
Take the fill hose off and aim it into a bucket and make sure the water pressure is good.
If thats all ok then you will need a multimeter and test the coils on the water valve and if faulty the valve will need to be replaced.
Check them and see what you find.
But the H20 error code is a water filling problem.
Aug 04, 2013 | Hotpoint Ultima WF860 Front Load Washer
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
Will this machine work with just a cold water supply
It should work with a cold water supply WF865 hotpoint if it has one connection on the back it is a cold fill machine all new machines are cold fill only hot fill has gone now. hope this helps.
Dec 27, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint aquarius wd640 my boiler has broke so could you tell me if my washer drier is a hot or cold water fill
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
WF860. Machine auto fills when power come on
this is for standard hotpoint washers.
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
this is for hotpoint lcd evo1 washers.
F12 - Communication error - Book a service engineer.
this is for hotpoint lcd evo2 and v4 washers
F12 - No communication between cards - Book a service engineer.
please do not for get to rate and comment about your experience with fixya today.
Aug 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint washer dryer
daidan, If you unplug the washer and it still fills you have a bad inlet water valve. If you post the complete model number we would be able to help you better...Catriver...post back
Aug 21, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
