Question about Kitchen Ranges
Tappan electric stovetop eyes will not get hot and the oven will
Stovetop eyes will not get hot and the oven will not heat
5 Suggested Answers
SOURCE: Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Posted on Dec 28, 2007
  • 145 Answers
SOURCE: burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Posted on Apr 23, 2008
Treefrog15
  • 127 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
  • 494 Answers
SOURCE: Electric oven does not work
After a power failure, some models will automatically resume their setting once the power is restored. On models with a clock, you must reset the clock. If the oven was in use, you must reset it by
pressing the CLEAR/OFF pad, setting the clock and resetting any cooking function.
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing
functions to work properly. The time of day
cannot be changed during a timed baking
or self-cleaning cycle.
Touch the CLOCK pad twice.
Touch the + or – pads.
If the + or – pads are not touched within
one minute after you touch the CLOCK pad,
the display reverts to the original setting.
If this happens, touch the CLOCK pad and
reenter the time of day.
Touch the START/ON pad until the
time of day shows in the display. This
enters the time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
CLOCK pad. The time of day shows until another
pad is touched.
If you do not have the owner's use and care manual,
go to this website and get a free download
of your manual by clicking on your model #.
Once you have downloaded it, you can print it up.
http://sz0047.ev.mail.comcast.net/zimbra/mail#4
Posted on May 17, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
The stovetop of my Tappan series 110 works, but the oven won't. What do I do?
if the oven wont fire up, 90% chance you have a glow rod failure, this is like a pilot lite
call a local service company.
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Tappan MPF500PBW Gas Kitchen Range
The stovetop works but the oven itself won't heat up... help?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 14, 2010 | Frigidaire GLEB27S7A Electric Single Oven
My Tappan Electric Double Oven heating element will not come on
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Oct 01, 2010 | KitchenAid Crisp/Conv M/W Over T/C Oven...
The stovetop of my Tappan 110 electric ignition gas range works, but the oven is out. What's up?
Most gas stoves use a ceramic ignitor that heats up before the gas is allowed to turn on. I replaced one many moons ago, not that hard.
Jan 10, 2009 | Kitchen Ranges
I have tappan ove that does not turn on. The gas is on and working but the oven does not heat up.
I assume this stove is new enough to have electric ignition. Also assuming that the stovetop burners ignite with the usual Tic-Tic-Tic, the electric igniter in the oven is probably burned out. Most igniters are of a ceramic material, coated with a resistive/conductive coating so it will heat to a cherry red glow to ignite the gas. Being ceramic, it will work wonderfully until one day it develops a crack, and no longer conducts. A replacement igniter is probably the answer. A local appliance dealer should be willing to sell you the part.
Dec 15, 2008 | Kitchen Ranges
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
RF315 Electric Range
It sounds like you need to replace your heat sensor located inside the rear left top of oven.Also you will need to pull range out and remove back panel to unplug senso good luck:)
May 20, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
