Question about Refrigerators
I can't find a replacement dispenser pad for my maytag sov626zb fridge freezer
    Champion:
  • 363 Answers
Check appliancefactoryparts.com
Posted on Jul 26, 2009
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
Maytag fridge side by side freezer door leaks water
If the insulation in the door has blown, it cannot be replaced. If there is a dispenser in the door, look at all the plastic parts for any splits or leaks. To test if it is the dispenser, turn off the water supply for a few days. If the water stops collecting in the door it's a good sign.
Apr 22, 2014 | Maytag MZD2766GES Side by Side...
Maytag MSD2574VEM00 refrigerator - ice does not stop dispensing.
Check to see if there is a lock button that will stop the ice from comming out then check the pad that you push on to get the ice and see if its stuck in , there is a switch behind the pad and it will need to be replaced
Jan 18, 2014 | Maytag MSD2756G Side by Side Refrigerator
Fridge/freezer leaks water
This is not very common. If you get water coming out of the ICE maker when you press the WATER dispenser, then the thing I would check first is the solenoid controlled water valve. It might be sending water out both legs at the same time. BUT if you have had work done on it lately, I would suspect that someone didn't get the electrical leads onto the control board correctly.
Jan 15, 2012 | Maytag Refrigerators
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Maytag MBB1954GES not cold. Fresh food area warm, motor not on. Freezer OK.
Check the freezer fan is running with the door switch pushd in by hand, check the back wall of the freezer for frosting if it's frosty check the defrost system eg defrost element, Defrost termination stat and defrost timer. If the freezers running perfect check the fridge difuser/damper and see if it's open this is the part that opens and closes the vent between the freezer and fridge to allow cold air into the fridge. The Damper is up the top left corner of the fridge. cheers.
Mar 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
