Question about Canon PIXMA MP830 All-In-One InkJet Printer
Getting the u150 error message too....
Hi guys...
Have just run into the same annoying problem. Have tried various combinations to sort it out with no luck - whatsoever. This is really the result of a bad design from Canon.... Right now I need to scan some important documents - but because of my u150 problem (that concerns ink) it is not possible.
I guess I have to buy a new chip and see how that works out... Canon ought to provide them in abundance when you buy the printer/scanner so that you don´t end up in this situation where you need your equipment on a sunday with no access to help....
Life is too short for this kind of ****....!!!!
  • 92 Answers
Hi ...
Error U150 normally comes in due to the ink tank ... Follow the below steps and I am sure you will be able to resolve this problem ...
I'll also tell you how you can find out what the problem is just by looking at the flashing ligh ...
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    NOTE: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press the ink tank's tab (1), then remove it from the slGetting the u150 error message too.... - sj403118.jpg>
  5. Unpack the ink tank and pull the orange tape off completely in the diGetting the u150 error message too.... - 05sj00141_05_en.jpgw and remove the film.
    Note: Tear the orange tape carefully aGetting the u150 error message too.... - 05sj00141_06.jpgline. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the Getting the u150 error message too.... - 05sj00141_08_en.gifr />Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
Hi. I have the dreaded u150 error. I have a
Hello !
Solution found on FixYa site:
Send an email to canon2.gif support explaining the problem. Tell them what you have tried, to fix your problem. They will send you an email informing you that your unit needs to be replaced.
Hope this helps.
Sep 19, 2009 | Office Equipment & Supplies
U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Getting ink cart error message U150
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Jul 26, 2008 | Canon PIXMA MP600 all-In-One InkJet...
No signal on my Benq DLP630 projector
please make sequences in switching on-turn your laptop on first and projector second-use fn key in combination of either f4-f5-f6-f7-confirm input signal selected(computer).
Jun 30, 2008 | Office Equipment & Supplies
U150 error message
There was plenty of ink left in my Cyan tank but just replacing it with a new Canon CLI-8C one, as suggested by techguru005, did the job. I suppose that the chip must have been faulty?
Let's see how long this one lasts!
Thanks, techguru005, it's fixed for now.
Jun 16, 2008 | Canon PIXMA MP810 All-In-One InkJet...
How do I resolve Error U150 on Canon MP810?
have had a MP810 about 3 months. Recently I've been getting a U150 error message. My C tank is not lighting up and being recognised. When I open up and replace the tank the light comes on. Initially this allowed me to carry on printing but now I have a constant error message even after replacing the tank.
Is there a permanent solution to this annoying problem?
I would be grateful for any assistance.
May 29, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Alarm light on, Display indicates error message: Check Ink U150 M
I added my post today with the same problem, and thought I'd share what I since learned. Apparently this "Alarm light/U150" is common with several Canon models. The U150 indicates a faulty electronic chip (on the ink cartridge). Though I tried cleaning the sensor with isopropyl alcohol, and also tried removing all the cartridges, unplugging the printer for 45 seconds, then reconnecting,etc. as I had read might help, I still had the same frustrating problem. Contacting Canon was the solution that worked for me. First I emailed, but decided I didn't want to wait for their response. A call to Canon Tech Support (1-800-385-2155) was quick and painless. They will more than likely send you a new cartridge, but you'll need to have your serial # & date of purchase handy.
Oct 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
385 people viewed this question
old marine
old marine
