Question about Sony XM-502Z Car Audio Amplifier
My amplifier and speaker works fine on Battery. After I start the car engine the amp runs for 5 seconds then shuts down and the power protect comes on. Turn off the engine and run the amp on battery again and all is fine until I switch the engine on.
  • craigp849 Jul 26, 2009
    I have checked the voltage produced by the battery and the alternator and they are both around 13.4V
  • 601 Answers
Hi ....
There seem to be a return voltage issue. Don't run the amp until you get it checked as that can create more problems. When a vehicle is running the alternator provides power to the whole system.
When a vehicle is not running the battery provides power to the whole system.
You have to get it checked for return voltage and low voltage produced by the alternator.
Let me know
Thanks and rate
Smith
Posted on Jul 26, 2009
  • Shereena M Smillan
    Shereena M Smillan Jul 26, 2009
    Amplifier going into protect mode is caused by too low of an impedance.
    You have to get the alternators and the wiring checked.
    Thanks
    Smith
Trick to reset pb1217x when protect light comes on?
if the amp is shutting down and the protect light is coming on you just have to let it cool down because it is getting to hot, sounds like you are pulling to many OHMS for the amp. if you are running your speakers bridged you can try running them unbridged (parallel) and that will drop the OHMS letting it run cooler. or you might have to try a different speaker/amp combination speakers might be to many ohms for the amp.
Jun 23, 2014 | Pyramid PB1000 MOSFET Bridgeable Amplifier...
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Amplifier cutts out when I hit my tilt trim button on my boat
Check all the speaker wire connections because the stereos will go into protection mode if you're losing or causing an unwanted grounding.. even on the speaker connections..
Apr 22, 2010 | Boating
Amp 7541a amp was working fine, Took it out of one
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. KEEP IN MIND, THAT DURING THE INITIAL TURN ON OF THE AMPLIFIER, THEY SOMETIMES WILL ILLUMINATE THE PROTECTION LIGHT WHILE STABILIZING THE POWER SUPPLY AND OUTPUTS, BUT AFTER THAT THEY SHOULD SHOW NORMAL POWER UP. IF YOU GET IT TO POWER UP FINE, THEN RECONNECT THE SPEAKERS AND IF STILL OK, THE RECONNECT THE RCA'S. IF IT IS STILL POWERED UP, THEN START TO TURN UP THE MUSIC. IF IT IS STILL POWERED UP AND NO MUSIC, THEN CHECK THAT YOU DEFINITELY HAVE A PROPER SIGNAL COMING FROM THE RADIO. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 18, 2009 | Infinity Reference 7541a Car Audio...
INFINITY AMP PROTECTION LIGHT FLASHING
Overload maybe. If the amp is run at an improper impedence, the amp will shut down. If you are "CLIPPING" speakers / subwoofers the light will blink to indicate a hard clip . Example: 4ohm/2ohm stable amp with 4 ohm subs wired at 1 ohm.
Jan 28, 2009 | Infinity Reference 7541a Car Audio...
Amp cuts off
The amplifier is going into protection. This may be caused by problems with speakers or wiring, or there may be internal problems in the amplifier. Start by connecting a known good speaker with a few feet of wire, and see if it runs without shutting down. If so, check the wiring and speakers. If the problem continues, the amp should be serviced.
Nov 23, 2008 | Crown XTi 2000 2-Channel Amplifier
Protection Light coming on with loud volume and power
It's most likely that the over-current protection is tripping at high power. At lower voltage, the amplifier can't produce as much output power and therefore can't produce enough current to trip the protection circuit.
You need to check your speakers to make sure that they are not shorted. With an ohm meter, the resistance across the voice coil shouldn't read any less than ~90% of the rated impedance.
If the speakers and the wiring are OK, the amp may have an internal fault causing the amp to go into protection.
Let me know if you have any other questions.
Aug 13, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
AUDIOBAUN A8002T Car Audio
add doide from the battery to the unit, 2 doide should help that.
1 connected to the positive, an 1 connected to the negative. 5-10 amperes is ok. check for the polarity. and try to take off the ground of the unit then try it.
Jan 15, 2008 | AudioBahn A8002T Car Audio Amplifier
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
Rockford P550.2 going into protect mode
Does it shut off for a couple of minutes or a couple of seconds? Is the amp hot when it shuts off? Are you sure you have the speakers wired to an acceptable ohm load for the amp? Have you measured the voltage at the amp (across the B+ and ground terminals) to make sure it's not dropping too low on hard bass notes?
Oct 08, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Sony XM-502Z Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
