It has to completely thaw first. If indoor fan is running and the filter is clean it is freezing up because of a lack of refrigerant .
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
SOURCE: Small pipe running from outside unit freezing up
SOUNDS LIKE THE FAN SPEED MAY BE TO LOW SO AS THE AIR GOES THROUGH THE COIL IT WILL START TO FREEZE HAVE SOMEONE CHECK THE FAN SPEED MAKE SURE IT IS ON HIGH ALSO MAKE SURE IF THAT IS THE ONLY FILTER ON THE SYSTEM
SOURCE: pipes frozen
zShut the unit off and let the ice melt.Just before that specific coil, you should see a valve with a itty ***** tube coming out of it. Follow that tiny tube and it should have a sensing bulb on its end clamped to the outlet tube of that coil. Make sure it is clamped prperly and there is insulation around it and and bare tubing before and after the bulb.If that bulb senses hot air itwill tell the valve to do thingds it shouldn't do. So, ck that out and let me know how it goes. Good luck-Ned_ Thanks for using fixya.com
SOURCE: 38cks is blowing air but it's not cooling
First thing, are the filters clean? If so then you have lost some gas from the system and need to find and repair the leak, and put in correct gas charge.
