Back to:
Tags:
Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t auiet pak 4 front load washer (by 3 users)
posted by ptqdale on Nov 21, 2007
After 20 minutes into the cycle the lights start flashing and error code f-20 appears and can't open door. How to fix
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by carmk, posted on Mar 19, 2008
I have the same problem. My door is locked and I can;t get my clothes out.
Comment by skdc, posted on Mar 16, 2008
After 20 minutes into the cycle the lights start flashing and error code f-11 appears and can't open door. How to fix
Best Solution
posted on Dec 29, 2007
FixYa! (100)
razingsons
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
I had a sock stuck in the drain. the bottom front of the washer has three screws that take a star shaped bit(screwdirever head) take those screws out and you can see the white clean out. If you open this, (turn by hand) you will find the obstruction. If the obstruction is not there, it may be elsewhere in the line.
You will get about gallon of water on your floors so have a couple towels right by you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Kenmore elite HE3t auiet pak 4 front load washer:
I don't want to Accept this solution
Solution #2
posted on Nov 29, 2007
FixYa! (100)
close
Rank:Wiz Wiz
Rating: 84%, 200 votes
is it pumping out the water?close let me know
Thank You!
Solution #3
posted on May 23, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
I had the same exact problem. I was getting a F-02 code. After alot of headache and searching I found out I had 3 baby socks stuck in the drain. Which explained why the water would not drain. There was atleast a gallon of water in the pipes so when I opened the cleanout.... WATER EVERYWHERE!!! make sure you have atleast 5 towels readyto go when you do this
Thank You!
Solution #4
posted on Dec 28, 2007
FixYa! (100)
lahunta
Rating: 100%, 1 votes
I'm havin the same problem. It will pump out the water after I press stop after that it stays locked until I press stop again. I thn put it on the rinse and spin cycle and it will complete this cycle with no problems. annette
Thank You!
Can you Help with these Washing Machines problems?
drum stuck
iam not really sure if there is a problem or not, it...
at the end of the cycle, the door is staying locked, all...
how can i do a model for a water cylcle
my kenmore elite front loading washer has some odd shaped...
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
