Question about Maytag SAV5710 Top Load Washer
Little black tube fell off rom under washer what is it and how do i fix it i have a maytag top loading washer
  • 199 Answers
This is from where your water is pumped out down the drain after the was and rinse cycles. It is attached with a hose clamp. Gain access to the attachment coupling, refit, and tighten the clamp.
Posted on Jul 26, 2009
I have a maytag top loading washer. the washer if set to medium load or large or super large load only fills to the half full level,
My maytag has a rubber tube that goes from the bowl up to the level sensor. I would try removing this tube and blowing it out to make sure that it is clear and not perished.
May 26, 2015 | Maytag Washing Machines
Why is there water in the floor model i just bought?
check your discharge hose in the back make sure it has not fell out of the drain a little. there is alot of preassure coming out of the hose. i'd say this is it . good luck
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune MAH1 won't stop filling with water and won't switch cycles...
Your washer has a switch which requires an air tight hose from the base of the tub to that water level switch. As water rises in that switch ,air pressure builds. When the pressure gets just right the switch kills the power to the water valves and starts the motor. So what can go wrong? A hole in the tubing, clogged tubing, loose tubing, or the tubing simply fell off. ea432a0.jpg
Oct 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I used the washer after several months of non use. Water flooded the floor! It did drain when I put it on spin.
The water level is controlled by a switch that attaches to a tube coming from the bottom of the tub. If that tube is compromised by a hole or simply fell off the switch then the water pressure won't build in the tube and shut down the switch.a329de6.jpgThe switch above is not exactly like yours. But it has a tubing going to it like that. Blow through the tubing to remove sediment then reattach the tubing securely. Pump out the water and then retry. No parts needed.
Rate it or hate it:1a2b3d0.jpg
Aug 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Washer does not spin but makes loud clicking noise?
sounds like you could have a problem with your basket drive tube,around the clutch brake area! my machine would not spin and i found out the bottom of the basket drive tube had been ground off by the thrust washer which resulted in the clip that holds the brake release arm fell off and broke the 2 little pins on the brake release arm and it would not disengage the brake to allow the basket to spin, i bought a used basket drive tube and a new clutch ,installed and unit works fine now,,,so take a look also check your motor coupling see if it is broken ,,, and 1 more thing ,up under your agitator is the basket drive block sometimes it shears off the notches on the top of your drive tube!
Feb 17, 2010 | Kenmore 24032\24036 Top Load Washer
My maytage washer would make a terrible screaching noise during spin cycle..now no spin cycle and something smells like electrical burning...I unplugged the machine. What has happened and what needs to be...
check your motor coupling, it is between the motor and transmission,made of rubber and plastic, if it is not broken and you heard a lot of screaching ,i would say it is your basket drive tube-could have gotten worn down on the bottom around the clutch brake area! mine sheared off the brass t post on the bottom of the drive tube,which my clip holding on the brake release arm fell off ,arm fell off and thus no spin,i bought a used basket drive tube installed it with a new clutch and is working fine now! a lot of work though to replace it
Feb 15, 2010 | Maytag PAV2300 Top Load Washer
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Maytag Top loading Washer, fills but won't stop filling and then overflows and will not start the cycle
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Mar 06, 2009 | Maytag PAV2300 Top Load Washer
Maytag Washer
It is the big container where you put the clothes inside, and you have an outer tube and an inner tube often called drum.
Move the mause on top of this diagram to identify washer parts.
Mar 03, 2009 | Maytag HAV3460AWW Top Load Washer
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Maytag SAV5710 Top Load Washer Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
