Monitor not working
My on/off switch on the monitor just clicks and flashes but no picture
i have tried it on another pc with same result
  • taffhassett Jul 26, 2009
    none of these answers work the monitor has got a mains dropper and runs on 12v it is an lcd type DIGIMATE L-1918
  • taffhassett Jul 27, 2009
    WHICH IS THE INVERTER
  • 241 Answers
If LCD screen, back light is defective and needs to be replaced by a qualified person.
If CRT type, high voltage circuit to CRT is defective causing intermittent hi-voltage supply. Not worth repairing. Better replace if CRT type.
I think this may solve your problem
Posted on Jul 26, 2009
  • 120 Answers
If this is LCD monitor, The power supply of you LCD need to be repair.Ask technician to fixed this power. LCD monitor need to epen and replace defective parts
  • ismash55 Jul 26, 2009
    If your LCD is 12v dc input.. One of the parts in inverter section of inside the LCD monitor is bad. Ask qualified person to do this.
Avocent kvm monitor flashing red light
So it's the monitor that flashes red? I would try the monitor on a PC to determine if the monitor is good. If not, replace monitor. If monitor works on a PC but not the KVM, power cycle the KVM. Depending on the model you may be able to do a hard reset. On other models you can access the KVM via IP to determine if there is an issue with the KVM.
Jul 29, 2014 | Avocent Computers & Internet
HP Mini 1000 VT won't turn on, lights flash when plugged in
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
C2Soluitons
Feb 14, 2012 | HP Mini 1000 VT series PC Notebook
Monitor boots up blank, I have to use an external monitor
Try to switch display output by pressing 'Fn' key with 'F4' or 'F5' key which has screen picture on it. Try it 2 or three times.
If it not works, then try it in windows, right click on desktop and in context menu see whether any display output option -> to monitor or to notebook. Click on to Notebook.
If still problem, you have to contact your vendor.
May 07, 2010 | Toshiba Satellite A105 Notebook
Acer CRT ac501 Monitor resoloution Problem The Picture Is Wider Than The screen How Do I make it Smaller??? I try To Adjust The Picture But No Result
Hi, this sound like you have a (Resolution) problem. First; (right) click on an empty area of your Desktop Screen, next click Personalize; click Display Settings from here you can adjust the resolution of your screen. You can repeat these steps until you are satisfied with the results. Thanks paul7of9
Jan 13, 2010 | Acer AC 501 15" CRT Monitor
ON/OFF SWITCH JUST FLASHING ON MONITOR
then the backlight or the inverter inside the LCD is bad. Replace or repair
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 26, 2009 | Computers & Internet
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Power button flashing green on and off. No Picture
What type of monitor do you have? I need to no if the power supply or cord plugs directly into the LCD Monitor? These questions are important! Please answer these questions, I will be able to give you an answer!
Nov 25, 2007 | Acer AL1916W 19" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
