Question about Meade LX200GPS Telescope
LX200 GPS Initializing
I bought a used LX200 GPS last week. When switched on, the display on the Autostar just shows "Initializing . . . Smart Drive" but nothing happens after that. On one occasion the scope turnd in RA for some time and then stopped but there was no change in the display.
I have kept the power on for more than half an hour with nothing happening and repeated it several times. I had switched on the scope inside the house to ensure that the initial setup etc., is ok. Later I moved it on to my roof top and tried to do the setup but the result was the same.
The person who sold me had told me that he had a problem when he had switched on inside the house and got it fixed with help fromMeade. I had tested it before buying and it seemed to be working alright.
Is there something wrong with the GPS or something else? The batteries are quite new and I think there is no problem with the power. It has 1.4g version. Can someone help? I am not in US and calling Meade is not really an option for me.
  • 37 Answers
I think you will find this link helpful. Good luck.
http://www.bisque.com/help/theskyV6/Telescope/LX200_GPS.htm
Posted on Aug 01, 2009
I just purchased a used Meade LX200 10" scope by mail. When I opened the box I found that the battery compartments AND the sheathing on the inside of both arms are missing. Have I been ripped off?
I assume you mean by sheathing the cabling to the RA and DEC motors and by battery compartment the control panel. If the seller stated that the scope was working, indeed you got ripped off. If by ratings you mean ebay I would contact them about a return and refund. If you got a great price, all is not lost since there is an upgrade to an autostar which will get you back in working order (but you need the RA and DEC motors). Autostar upgrade is about $ 520 but you will still need a 12V power supply. George Dudash 760 383 2741 sells these kits and can probably get the other parts you need to get going. I'm guessing this may cost around $ 800 total from what you say. If you paid more than $ 1000 for that scope I'm afraid you were ripped.
Mar 01, 2015 | Meade 10" LX200GPS Schmidt-Cassegrain...
Hello my name is greg i have a lx200-acf from my dad when he passed away do not no howto use it ?
This is a great scope. I have a much smaller version :)
1. Take it out on some dark night. 2. Let it auto-align 3. Select something to look at using the AutoStar II 4. Press Go.
Gander at the wonders of the universe.
In the AutoStar, there is a program called Sky Tour. This will pick some things out for you.
Start with a "wide" eyepiece - to see more of the sky. Work your way to high powers as you need or as sky conditions permit.
Goto a few local "star parties".
Jun 02, 2011 | Meade 12 Inch LX200ACF Advanced Coma Free...
I have an older Meade LX200 GPS with autostar II handset. The telescope was working fine and last night I got an error message on the handset "Error: Inv. Heap" and the telescope locks up with no further...
You may have Corrupted firmware in the hand controller- that's why they want you to do a RESET.
You might have to reload the correct firmware to fix this problem.
I believe if you hold down the ENTER KEY and the SCROLL DOWN arrow key and then turn on the scope you enter SAFE LOAD where you can reload the firmware.
Sep 02, 2010 | Meade Optics
Etx-ls update to 1.2g failed, how to i restore or try the update again the autostar iii handbox does nothing
Easy.
If the firmware in your Autostar crashes and you cannot access the "DOWNLOAD" menu item on your handbox, you can use the "SAFE LOADER" feature of your new Autostar software. To get into the safe loader, follow these simple steps: 1. Make sure the Autostar and ETX are turned off.
2. Press and hold the "ENTER" key and the Scroll Down Key located to the right of the help key on the Autostar handbox.
3. While depressing both keys, turn on your Autostar power switch. This will require you using both hands.
You should see "FLASH LOAD READY" on your display. This indicates that you can proceed to Update new software to your Autostar.
Oct 08, 2009 | Meade Optics
Initializing Smart Drive... forever
I have a similar telescope, and there is nothing that gets dislodged by nudging. HOWEVER a major problem is with the Declination drive gears. They are plastic and can loose a tooth really easy. If the is a problem, then you should hear 'skips' when the drive is moving the motor. Smart drive moves the telescope to read the feed-back position dist, and to see the 'home' position magnet. If the sensor is out of place then it will do as you see.
Aug 20, 2009 | Meade LX200GPS Telescope
Autostar when energy is on only shows the lx200 gps sign but does not initialize
Do a RESET on the hand controller. Then Train Drives. Make sure TIME and DATE are correct, and Daylight Savings is YES
Aug 09, 2009 | Meade LX200GPS Telescope
Meade LX200GPS 8" won't initialize on power up.
Try doing either a garbage collect or a safe load-- and then reinstall the hand controller firmware--
Instructions-- depending on the type of controller
Autostar 495 or 497: You enter Safe Mode by holding the [enter] and
[scroll down] keys pressed when you power up the telescope. The
Autostar will say "Flash Load Ready"... now go start the ASU.
Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
LX200gps: BEFORE proceeding further, click on the OPTIONS item on the Top Bar.
Now click on "Garbage Collect Hbx" ... this will perform data cleanup
within the Autostar which will avoid potential mess-ups.
Feb 27, 2009 | Meade LX200GPS Telescope
Backwards?
Check the Autostar controller for a stuck direction key.
Jul 02, 2008 | Meade LX200GPS Telescope
Meade LX200 10" SC Telescope
You have a standard lx200 problem. If you transported your scope a lot with the drives "locked" it damages the RA and DEC drives. If you keep using it, the motors burn out and start drawing too much current. This sometimes blows the motor driver chips on the motherboard which are getting very rare.
The burned out tantalum caps can be replaced with better aluminum electrolytics very cheaply. If the ones in your Autostar burned out, they often burn up the ribbon cable. Also, they often take out U11, a 74LS14 chip on the motherboard. Also a cheap repair. You should take the Autostar apart. If they are burned up, it will be obvious. If your ribbon cable survived, you should replace the caps with aluminum electrolytics. I believe they are 6.8 uf.
So, if you can work an ohmmeter, measure the resistance of the two drive motors with the plugs unplugged. If it is about 14 ohms they are ok. If they are about 3 or 4 ohms, they are toast. Check the worm drives for end play. If there is just a little, you can adjust them. The battery jack on the control panel often breaks the solder joints on the board, causing one of the problems you describe. You can check that and replace/resolder as necessary. The on/off switch often fails and gets intermittent. These are also cheap and can be replaced. I don't repair these for a living but I repair a few of them for friends in the club. These are pretty common problems.
Feb 27, 2008 | Optics
Meade LX200GPS Telescope Logo
332 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
