Borland C array size limit
I crate an array [65535] size and it's fine, but for a bigger array size like [70000] it's tell me too large, how can I change it I need 640x350 and more. Please help, and explain me how and what to do and what is this, thanks.
Comments:I work in Borland C more then 1.5 years so newbies please stay out!!! (like try float instead of int, learn data types first!!)
  • 1,263 Answers
Hi , if you look at some of the postings you find the answer
http://bytes.com/groups/c/530395-array-size-too-large
Regards
Posted on Jul 26, 2009
Large pictures don't display
Many digital photo viewers can only display photos of a certain size or less. Check your owner's manual, or find the manual online, and it should tell you what the upper size limit is for your viewer.
Jul 04, 2014 | Kodak Digital Photo Viewer
How much max hdd can connect to intel pentium dual core e2180
As of now there is no real limit.
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partioned. So a single 4TB (biggest on the market) drive will look like serveral drives.
External drives that are bigger than 4TB are really serveral physical drives combined by an array.
Sep 28, 2012 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
How do I determine the size of crate I should buy for my dog?
The crate should be large enough for your pet to lie down comfortably and also turn around with ease. If you are buying a crate for a puppy, try to buy one for the size he/she will grow to fit, rather than the size they are now.
Sep 03, 2012 | Pets - Others
How to change font size in borland turbo c++ 4.5
go to Option
now select environment.
a pop dialgo box will open
Now click on the editor node to expend it
now click on dispaly
in the right hand site there is an option to change
the font-size and font-style
Jul 30, 2012 | Borland Turbo C++ 4.5 Full Version for PC
I have to tutor tasm.exe and i need sample programs with explanation
Write a program to find out the largest number from a
given unordered array of 8-bit numbers. Store the largest
number in largest variable.
52h, 23h, 56h, 45h, 9Ah, ABh
Aug 12, 2011 | Borland Turbo Assembler and Debugger 5.0...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to install borland turbo c 3.0 in windows 7?
borland turbo c version 3.0 is not compatible with windows 7 i myself have faced the problem try using borland c++ version 4.5 its works fine
vote me click thumbs
Feb 16, 2011 | Borland Turbo C++ 4.5 Full Version for PC
Hwo can i solved a bineary search problam in c++
first arrange your array in ascending order.and keep the two variables one for starting index and one for last index
then check your number with center(center = (first index + last index))/2 element of array.
if it is lager then center element then set first index = center,
if smaller then last index = center
else you got the number..
Jul 25, 2010 | Borland Turbo C++ Suite 1.0...
What engine size do i have? chevy 1968 c10 vin
Check this website and double check your vin number to see if its correct. That way you can determine what you have for your engine sixze. If your engiune number had CE at the very beginning it would be a replacement Crate Engine. Yours is not a crate engine replacement as far as I can tell from the numbers you posted
http://www.nastyz28.com/decode.php
Apr 08, 2010 | 1978 Chevrolet C1500
Memory limit in Borland C
you might be using integer value
try using float it might work
vote please
Jul 25, 2009 | Computers & Internet
Computers & Internet Logo
487 people viewed this question
David Payne
David Payne
