Question about HP Photosmart C4180 All-In-One InkJet Printer
Where does power plug into printer ?
Where does power cable plug into printer ?
  • 32 Answers
User Manuals-
Try this one: click here (quick start) and this one: click here (Basics Manual)
Hope this helps
-samson39
Posted on Jul 26, 2009
I need to know where to plug power cable and what type power cable i need
When you buy a printer power cable tell to the salesman/saleslady about the model of the printer for them to match your printer...
You can locate the input power chord into back or side of the printer...then plug that power cable into outlet to power on the printer
Note: Do not power on the printer until your pc configure it
Sep 20, 2011 | HP PSC 2210 All-In-One InkJet Printer
My printer won't turn on
Hi
Either the power source has issues or the power jack on printer has gone bad or printer's main board has issues.
Verify that the electrical connections and outlet are functioning:-
Unplug the power cable or power module from the electrical outlet.Unplug the power cable or power module cable from any power strips or surge suppressors.If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.Unplug the power cable or power module from the back of the product.Wait at least 30 seconds, and then plug in the power cable or power module into the electrical outlet.Plug the power cable or power module back into the product.Turn the product on.
If this doesnt help, take the printer to another room and plug it in another power source.
If this doesnt help, use a multimeter to check if adapter is giving out right voltage.
If adapter and power source are fine, then your printer has a hardware issue and needs to be repaired by Canon.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
The printer does not reboot when power plugged in.
Try using these steps to resolve your issue.
  1. Unplug the power cable at the back of the printer
  2. Wait for at least 1min.
  3. Plug the power cable back in to the printer and on the other end of the cable, make sure that it is plug in directly to the wall outlet (please make sure that you are not using any power strip or surge protector.)
  4. If its still not working try using different cable.
  5. If its still doesn't work, call HP and have your printer trade in. ( 1-800-474-6836 )
NOTE: If your printer is no longer covered by the warranty and you are asking for replacement, charges may apply.
Feb 19, 2011 | HP PSC 2210 All-In-One InkJet Printer
HP C8189 All in one printer....Error Oxc 19a0005
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. Use a moist cloth to clean the nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the cartridges.
Now see if its working fine. Let me know.
Dec 02, 2010 | HP Photosmart C8180 InkJet Printer
Canon ip1980 model printer's (ink absorber almost full problem)
release cable power and usb press and hold power button than plug cable power to printer port, pres and hold resume button 18 second or more, than plug usb cable into printer, press power button (printer off), and press again power button (prnter On), thats alll.... thas working to my printer (ip1800, ip1850, and ip1900, ip1980)
Nov 30, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Our canon MP560 printer will not turn on - it was plugged into a surge protector and we have tried moving the plug to alternate outlets just to make sure that wasn't the problem...help!
This is what worked for me. I had a similar setup and could not get the printer to turn on. Remove the power supply from the back of the machine. It is a very simple process: pull apart two small plastic connectors with your fingers to remove power supply. Disconnect internal blue cable from power supply.
Replug blue cable and be sure it is plugged in tight.
Push power supply back into place, be careful of blue cable when pushing it back into printer.
Plug in and printer just may work...good luck!
Jun 28, 2010 | Canon MP560 All-In-One InkJet Printer
No pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
HP OfficeJet 6210 printer
unplug all the cables ang plug them back in
also try reseating the cartridges
May 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Printer will not turn on
The all-in-one product will not turn on If the all-in-one will not turn on at all, follow the steps below in order to determine the cause:
  1. Verify that there is power at the wall outlet.
  2. Verify that the computer and the all-in-one product have a three-prong power plug.
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  5. Plug the power cord into a different electrical outlet.
  6. If the all-in-one has an ADF with an external cable plugging into the back of the product:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      • If no change, the problem is not the ADF.
      • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
      • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  7. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
Nov 12, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
