Question about Dayton Permanent Split Capacitor Motor Fan
Does Dayton Capacitor Start Model 8GN60 Exist
  • James Ely May 11, 2010
    I could not find it but that does not mean it does not exist. I tried replacing the 8 with a B and the zero with an "O" and still no luck. It doesn't look like a Dayton model number either.
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Need the size of the run start capacitor for a Dayton 1/2 HP motor #5K529A. Also where can I get one along with the cap cover for the motor and a key for the shaft?
all those items you can easily obtain right from the Home of Dayton , ( Grainger.com) as Dayton is there stock brand
and with there huge system of local stores too , im betting there's one within a short ride to it near you .
Oct 26, 2015 | Dayton Dryers
What run capacitor will work on dayton fan motor model # 2LY97A
Over heating and like most new product these days throwaway planned obsolescence and made to fail
Feb 10, 2015 | Dayton Dryers
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
Dayton motor, 1/3HP, D/D Blower will not star without a spin by hand. Run fine once started, but must have the spin again to start. Is there a stadt capacitor and where ?
The cap is either external or under the bump on the side of the motor... but yeah, that is what is wrong, the cap went bad...
heatman101
Aug 18, 2010 | Dayton Permanent Split Capacitor Motor Fan
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Capacitor
Here is a link to a distributor with fan specs : http://www.grainger.com/Grainger/wwg/productIndex.shtml?search_type=keyword&QueryString=3C325B&operator=refineSearchResults&originalValue=Dayton+Fans&searchIndexId=1&typeOf=
I do not know which specific motor is used on that fan ( that fan has been discontinued) however you can check out this link http://www.emotorpro.com/index.asp?PageAction=VIEWCATS&Category=280
and have a representative that sells Dayton products answer your question... Hope this helps you...
Sep 09, 2008 | Dayton Permanent Split Capacitor Motor Fan
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
Dayton Permanent Split Capacitor Motor Fan Logo
204 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
