Question about InFocus ScreenPlay 61" Rear Projection HDTV
Dark -- background seems to dark with night time shows
Is it the bulbs ? tried to adjust still to dark
To check your lamp useage hours: 1. turn on TV by touching the POWER button on the TV, not on the remote
2. press and hold CHANNEL DOWN and MENU on the TV
3. using remote, select "SERVICE ALIGNMENT (or something)" from the menu. 4. press VOLUME UP to V90
5. press CHANNEL UP If you have around 1500-2000 hours, then you'll need a new lamp soon. Don't wait too long... It will get dimmer and dimmer at an ever-increasing rate.
Posted on Aug 07, 2009
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
http://waterheatertimer.org/How-to-set-timers.html
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
Sep 17, 2014 | Hardware & Accessories
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
BACKGROUND LIGHIUNG SEEMS TO BE GETTING DARKER.
Your set contains three projection tubes (picture tubes) the typical life of these are about half that of a regular picture tube television, around 20,000 hours of operation.
As those tubes age the light emission from them slowly starts to decline. Other symptoms include colors being off slightly or a greenish screen. The symptom you are experiencing is called "contrast loss". That means the difference between bright and dark features in your picture tend to get closer together. This loss of resolution (also the picture might start to get fuzzier then it used to be) is a function of your projection unit wearing out. Since it costs nearly as much to replace a set of tubes (all three must be replaced at the same time) as to replace your set. I would suggest taking your time, read reviews and look for a new set.
Regards.
Zashiban
Regards.
Zashiban
Jun 25, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Dark Pictures
try reseting the camera back to default settings, there should be a function for that in the menus or a small reset hole somewhere in the camera.
Jul 23, 2008 | Canon PowerShot A640 Digital Camera
Ghosting problem with Christie LX 45
reset the settings to factory default and make sure the resolution matches. you can adjust the clock and phase in the menu.
Nov 16, 2007 | Christie LX45 Multimedia Projector
INDOOR PICTURES ARE TOO DARK
try using the night shot it will go slower but it works well for dark pleases
Dec 17, 2006 | Aiptek MPVR Digital Camera
InFocus ScreenPlay 61" Rear Projection HDTV Logo
177 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
