Question about Dell Inspiron 6400 Notebook
Keyboard doesn't type letters, only commands
My keyboard on my desktop computer is acting like the control key is stuck down even though it isn't. Any suggestions?
  • clarin895 Jul 26, 2009
    it's not a dell and its not broken, this has happened before but it always seems to just go away after a while but now it's not
Dell is garbage throw it out
Posted on Jul 26, 2009
  • mez36 Jul 26, 2009
    dell is garbage throw it out
How can I stop the keyboard from printing multiple letters with even the barest touch. It doesn't happen with touchpad typing.
this happens when there is a key stuck down or the key is faulty. There is a place in the control panel section of the computer that has a key speed selection but I think if you use another key board the problem will go.
Feb 01, 2015 | Computers & Internet
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Key stuck on (keys are loose, not actually stuck) but works ok with external keyboard
There's more than likely something sticky in your keyboard, someone probably spilled liquid in there and now it's sticking as though your pressing even though you aren't.
A new keyboard will fix this problem.
Jul 18, 2012 | Computers & Internet
IMac keyboard suddenly isn't working. Mouse works, but I can't enter any typed message.
if it's bluetooth, are the batteries ok and is it showing up in your bluetooth settings? if it's wired, try another usb port
Oct 21, 2011 | Apple iMac G5 Desktop
My keyboard acts crazy: it does not type all letters, numbers, enter key and maybe some more. it DOES do keys like alt. ctrl. shift, start. same problem with 3 different keyboards: 2 USB ones and one...
Welcome to Fixya. To be able to know if this is a problem with the operating system or with the hardware of the computer. We need to check if this is happen inside and outside windows. Open command prompt when you are inside windows and observe if the keyboard will type on command prompt window or it will act as the same as when your typing inside the windows operating system. If this problem only occurs within Windows it means that this is a problem with the operating system. However if this also happen on command promt it only means that this is a hardware issue or a motherboard issue. Please let me know if you have questions on the procedure and on what happen.
Thanks
Sep 16, 2011 | Computers & Internet
My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
  1. Click Start
  2. Click Control Panel
  3. Click the Ease of Access heading.
  4. Click Change how your keyboard works.
  5. Remove all the check mark in the box next to "Turn on Filter Keys".
Enjoy :)
~ Vikrant (India)
Dec 09, 2010 | HP Computers & Internet
Definition for keyboard
As the name implies, a keyboard is basically a board of keys. Along with the mouse, the keyboard is one of the primary input devices used with a computer. The keyboard's design comes from the original typewriter keyboards, which arranged letters and numbers in a way that prevented the type-bars from getting jammed when typing quickly. This keyboard layout is known as the QWERTY design, which gets its name from the first six letters across in the upper-left-hand corner of the keyboard.
While the design of computer keyboards may have come from typewriters, today's keyboards have many other keys as well. Modifier keys, such as Control, Alt/Option, and Command (Mac) or the Windows key (Windows) can be used in conjunction with other keys as "shortcuts" to perform certain operations. For example, pressing Command-S (Mac), or Control-S (Windows) typically saves a document or project you are working on. Most of today's computer keyboards also have a row of function keys (F1 through F16) along the top of the keyboard, arrow keys arranged in an upside-down T, and a numeric keypad on the right-hand side. Some keyboards have even more buttons, allowing you to change the system volume, eject a CD, or open programs such as your e-mail or Web browser.
Nov 05, 2010 | Computers & Internet
Keyboard typing extra letters >.<
Sounds like the windows key is stuck down, pressing start+r opens run, start+e opens explorer etc. The start key being the one between control and alt.
May 25, 2009 | Computers & Internet
Compaq presario c700 keyboard mulfunction
There are 2 common problems for this.
1. Something got stuck under the keyboard of your laptop. Food scraps or Dirt and Grime build-up due to sweaty palms or fingers clean the keyboard.
2.The Membrane on your keyboard that act as a switch cold be shorted due to wear and tear or heavy key presses. Have your keyboard replaced.
Other problems could be cracked board if you happen to lean or put heavy stuff over the keyboard and cracked ribbon connector.
Jan 21, 2009 | Compaq Presario 700 470024-192 Notebook
Rt7d40 dell keyboard is non responsive
probably need to clean your keyboard
check keyboard settings in control panel
Nov 13, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Inspiron 6400 Notebook Logo
239 people viewed this question
Alun Cox
