Question about Masterbuilt Grilling
Masterbuilt 30 in electric smoker, keeps kicking off breaker. Possible problems?
  • 14,384 Answers
They all do this,they are junk,check these links out. Masterbuilt Smokehouses
Posted on Jun 09, 2017
How do you put together for masterbuilt electric smoker
Masterbuilt should have a website with a pdf download of the instructions. Google that and you should find it.
Sep 01, 2014 | Masterbuilt Electric 30 inch Digital...
Masterbuilt smoker error message EA2
EAA2 means connection to the meat probe is lost. Either a broken, burnt wire or the probe itself. Check the probe wire carefully to spot a break.
Jul 05, 2014 | Masterbuilt 20070411 30" Electric Smoker...
Smoker throws breaker
Larger breaker.... Or split breaker....what size right now??
Nov 19, 2012 | Masterbuilt 20070106 Electric Smoker
Eeaf smoker keeps tripping off
Hi sally mako...
Make sure your breaker is strong enough to handle the ampreage draw of the smoker element.
Try a different receptical with a known larger breaker...
If still kicks the breaker, then remove the electric plug from the receptical and check all connections on the element and controls to make sure they are not corroded or broken and shorting out.
Please take time to rate me
Sep 24, 2011 | Masterbuilt 20070106 Electric Smoker
I need an element for Mod: 20070106 Ser.# GA040925
You can purchase a new heating element part # 990050051 either from Masterbuilt or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/masterbuilt/
If they are still available. All of Masterbuilt's electric smokers have been plagued with electrical problems.. It's either the element or the electronic controller on the top of the smoker, that constantly fail.
Hope this helped you and thanks for choosing FixYa.
Sep 20, 2011 | Masterbuilt 20070106 Electric Smoker
I am new to smoking. I have the Masterbuilt 30 inch electric smoker (model 20070410). When do you use the water tray - put water in it. I know to use the wood chips, but when should I add water to the...
According to Masterbuilt, you should use water all the time. It pan should be filled the the lines indicated on the pan, prior to turning the smoker ON.
Aug 13, 2011 | Masterbuilt Electric 30inch Smokehouse ...
I have a Masterbuilt electric smoker and have lost the instructions that came with it. Would instructions from a different smoker work with my Masterbuilt? Do you know how I might get the Masterbuilt...
Masterbuilt makes several different models of electric smokers. f you can furnish the correct model number of yours, I may can help you.
Thanks for choosing FixYa.
Aug 05, 2011 | Grilling
I NEED A MANUAL FOR MY MASTERBUILT ELECTRIC SMOKER
Here is a link to the Masterbuilt Smoke House 30" Electric Smoker, Model # 20070210. Which is what I think you have. You can download and print the manual.
http://www.masterbuilt.com/pdf/manuals/20070210%20ESQ3082%20Manual.pdf
Hope this is what you need. Please let me know.
Mar 07, 2011 | Masterbuilt Electric 30inch Smokehouse ...
Electric smoker is now tripping GFCI breaker
GFCI breaker tend to wearout and become more sensitive after time and use. Motor loads are especially hard on them. Also resistance loads such as heating elements. Your smoker may be pulling a bit more electric than it used too.
Check the power draw of the smoker when operating, if it is high then fuigure out why. It it is normal then replace the braker. Use a regular breaker if the GFCI is not required, or run a cord from an outlet that is not on a GFCI breaker.
Heatman101
Jan 24, 2010 | Masterbuilt 20070106 Electric Smoker
The heating element doesn't come on, the control pad all works and the element ohms out good. where can I get electric parts and a wiring diagram for my 30" Masterbuilt Electric Smokehouse?
Hold a warm rag over the end of the thermocouple sticking out of the back, INSIDE the smoker. When the probe gets up to 40F or so the element will turn on and you will be good to go. The computer just doesn't understand whats up when the thermometer gives such a low reading.
Nov 04, 2009 | Masterbuilt 20070106 Electric Smoker
Grilling Logo
328 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
