Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not fill up
I have a ultimate care II washer that is about 5 to 6 years old. recently it has been just filling up and draining at the same time so it constantly tries to fill up. I have to manually turn it to agitate and also do the same for the spin cycle. My clothes after that are still soaking wet.
  • 93 Answers
IS YOUR DRAIN HOSE AT LEAST TO THE TOP OF THE MACHINE - OTHERWISE IT MAY RUN OUT OR SYPHON OUT/
Posted on Jul 26, 2009
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool 3 year old washer
sounds like a bad basket drive.i don't know why after only 3 years though
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II - Whinning and leaking small amount of water
If the water is appearing in the front of the washer, you may have a leak in the drain pump. The link I'm posting below gives step-by-step instructions on how to replace the drain pump.
http://www.fixya.com/support/r397092-replacing_water_pump
If it is not the drain pump, at least this gives you the necessary instruction on how to access the cabinet interior to inspect it properly. A whining noise could be something caught in the pump, or something stuck between the wash tub and outer basket. In order to run the washer with the case removed, you will need to by-pass the lid switch. this accomplished by jumpering the two BLACK wires on the lid switch connector at the timer. CAUTION: Unplug the washer before connecting the jumper wires. Then, plug back in and start the washer. Fill on the lowest setting and look for leaks.
NOTE: The drain pump is not serviceable and must be replaced if leaking.
I hope this helps you. Let me know if you have further questions.
Jun 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Barberboss
need more details please stopped what wont fill wont spin wont drain does it make any noise ?? does it fill and not wash
May 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
