Installing Windows XP on a pc I have just assembled myself. All was going well until during setup Windows said it was going to 'adjust the monitor for better resolution' and asked for an 'OK' response. Unfortunately my USB drives are not yet activated (so no mouse) and Windows will not accept a command from the ''Enter' key. Thoughts gratefully received. Cheers.
  • 4 more comments
  • Peter Sullivan Jul 26, 2009
    Thanks for the tip. Unfortunately, it is a typical Windows dialogue box. It has a mouse pointer symbol and an "OK' box. I tried the USB ports but they are inactive. I was following the process in the manual which says to choose DVD as boot device in BIOS and then the screen prompt was to install the Windows disc. Since then the keyboard has allowed me to respond. This has thrown me.I don't want to swith the system off and take that risk if I can avoid it. Keyboard lights are on, but the system is clearly waiting for me to respond.
    Cheers.
    Hi folks thanks for the tip about starting in safe mode. How can I exit setup without causing damage?
    Thanks for that. I have tried Ctrl, Alt, Del but the system is waiting for me (as Windows sometimes does) and will not accept any key strokes. Is there any other way of exiting setup without crashing it by turning off the power?
    Thanks I am off to try that.
    Cheers.
    Thanks everyone for the help. Problem resolved. I powered off, restarted in BIOS made sure USB ports were enabled (they were!)and saved and escaped to Windows, I couldn't start in Safe Mode, but it now recognises the mouse so I am up and running. Thank you very much. I am happy chappy! You are stars!
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Does the "o" in ok have an underline under it? If so you just hit the "o" key on the keyboard to accept the command. Hope this helps.
  • 192 Answers
If you have an old ps2 mouse lying around, this would be your best bet. I'm sure some of your mates would have one (or a ps2 adapter) lying around.
I don't recall that it will not accept an "enter" for the OK. You may have to use the "tab" button to highlight the OK button, then press the enter key. As well, you can startup in safe mode (press F8 whilst starting), and load your usb drivers, although if you are using XP, it should notice your USB ports, just may not have the correct drivers if say, you have USB 2.0 ports. If you need followup information, please write back.
Thanks for using FixYa.
Posted on Jul 26, 2009
  • Kreesha Fletcher
    Kreesha Fletcher Jul 26, 2009
    If you press ctrl+alt+del you shoudl be able to restart. The display settings are very near to the end of setup, and you can always "fix' an installation by inserting the disk at a later time. As a matter of fact, it should notice where it leaves off and continue on if you leave the disk in. If not, then you would deal with the installation again.
  • Kreesha Fletcher
    You're absolutely correct in that it will not accept other keystrokes if that OK button is still up. Do a hard reset by disconnecting power, restart in safe mode and it *may* continue where it left off. If not, once again, you can repair an install if you are to get to the desktop and utilise a mouse. So you have no ps2 mouse at your availability? Nor your friends? Try the safe mode solution then, and I believe you may have USB port functionality at safe mode.
    President:
  • 1,884 Answers
When you boot your computer, just after the BIOS finish checking, press F8 key. Run windows in Safe mode. When the machine boots and gives you the screen, set the display to the lowest and reboot. On the next reboot adjust display one notch at a time and when you get a blurred display press Esc to come out as it does not suit your monitor. Adjust display one notch lower and accept it as final optimum display.
  • Vinay Tevatia
    Vinay Tevatia Jul 26, 2009
    On the next reboot adjust display one notch at a time and when you get a blurred display press Esc to come out as it does not suit your monitor. Adjust display one notch lower and accept it as final optimum display. he mouse should work in Safe mode.
  • Vinay Tevatia
    Nothing shud go wrong if you power off the computer and re-install XP. Your time wud have been wated but its better utilised reinstalling XP. When you come to the same "adjust monitor for better resolution" click on the X in the right top corner of the window. If the mouse is not working then press Alt + F4 to close the window. Then in the next reboot use safe mode as told earlier. And have your fingers crossed all the time. It may be that you monitor is not matching the XP's required setting. So one notch lower shud be fine.
  • 49 Answers
Your pc has not found the driver of usb first check it
Posted on Aug 16, 2009
Testimonial: "This was the problem. Thanks."
Im using acer laptop, my mouse and keyboard stops working during windows xp installing, why??
When you turn it on, do you see a message to press F2 (or some other key) to enter setup? If so, go into that and change the settings to default, and save and exit. See if that doesn't help things along. If not, Windows XP can sometimes 'hiccup' on some hardware problems during installations. If it doesn't like what's happening with certain hardware, it will fail, or freeze.
Hope this helps.
Jul 22, 2013 | Computers & Internet
My htc t mobile phone geting problem during pc connect. pc needs its drivers can i get it? model is ELF0300
go to the site below to get the files. download the software and install on your windows pc. Note that this is not needed if you run windows vista/ windows 7. hope the links below will help. after installing the software connect the phone (remove the phone during installation and reconnect after installation)
click HERE if running Windows XP/server/98
(make sure to download "setup.msi " = that is what is needed)
Windows 7
This will be managed through windows mobile Device Center and no software needed
if you are still having problems do let me know.
good luck
Nov 11, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
Hi... I have a problem during installing Windows Xp in my laptop, im getting an error message like 'setup did not find any hard disk drives installed in your computer.... plz.. help me out...
reboot your computer and hit f2 when you first see the logo popup, this will take you into the setup. Arrow over to boot at the top of the screen.hit f5/f6 until your cdrom drive is first on the list. Arrow over to exit and save changes and exit. Before you hit enter, put your XP cd in the cdrom so it will boot to cd when you restart. You should be able to reinstall windows doing this. When you are done, to reverse the process and return your bootup to normal default, hit f2 at the logo, when you are in the setup utility hit f10 to load setup defaults and exit, your computer will reboot and you should be good to go!
Oct 11, 2010 | Computers & Internet
Can't install xp
Are you receiving any error messages when you try to install Windows XP?
If it is not detecting your Hard Disk follow the steps below:
Go into the BIOS setup (press f10 during boot process), System configuration and disable SATA Native Support. Try installing XP again and it should see your hard drive.
May 18, 2010 | Compaq Presario 700 470024-192 Notebook
Monitor goes to BIOS Screen Repeatedly
Your monitor is fine, the problem here is with your computer, and sounds like a virus. Time to competely reinstall windows, or have a tech look at the computer.
Aug 01, 2009 | Microsoft Windows XP Professional SP2 Full...
Computer hangs during xp installation
make sure you have met the minimum hardware requierments when installing your XP...which is
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Apr 11, 2009 | Microsoft Windows XP Professional for PC
I have a wd sata hard disk and i cant setup windows xp on it, it the monitor says ..... " windows can not find any hard disk instal into your motherboard " i need to solve this problem please thank you
Windows XP didn't have support for sata drives. You will need to load the driver by pressing F6 when you start the Windows setup. You will see the message
Press F6 to load 3rd party drivers at the bottom of the screen when Windows is installing.
Apr 06, 2009 | MSI Computers & Internet
Auto Adjust
I have found a way to stop flickering of auto adjust - press the menu key on your monitor -factory reset-menu button-all settings. That has solved my problem and hope it helps you.
Sep 04, 2007 | ASUS VW192S Monitor
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
