Question about HTC G1
Motorola W270 Memory Card problem
My handset has a 2 GB memory card but it doesnt display. When I connect the handset to the PC through a USB cable it doesnt show up.
  • 71 Answers
You need to reset memory card settings. scan your memory card with an antivirus. format it.
Posted on Jul 26, 2009
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
W270 modem drivers
MY MOTOROLA W270 IS UNABLE TO PLAY SONGS OF MEMORY CARD
Sep 06, 2010 | Motorola Mobility W270 Cell Phone
MEMORY card
Hello there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Aug 03, 2010 | Motorola Mobility W270 Cell Phone
    I need data cable drivers for my M300 samsung mobile phone
    If you are looking for drivers for moving, adding/removing pictures or mp3's try this.
    Transfer MP3 to M300 without driver
    1. While in standby mode, plug in the USB cable to the handset and connect it to a USB port on your PC
    2. While in standby mode, press the Menu/OK key
    3. Select Tools (9)
    4. Select Mass Storage (1)
    5. Select Connect to PC (1)
    6. The handset should display the message, Connected to PC & Call Disabled
    7. Open Windows Media Player 10 on your PC and select the SYNC option
    8. The left-hand side of the Windows Media Player will display the files on your PC, Check the songs you want to download
    9. Press the Start Sync button on the upper left-hand side of the Windows Media Player
    10. A Synchronization Complete message will appear on the phone when downloading is complete.
    11. To return to standby mode, press the left soft key for Done then select Yes (1)
    12. Disconnect the USB cable from the handset & PC
    Transfer Pictures and Video without driver
    1. Insert a microSD memory card into the handsets microSD card slot Connect the USB cable to a USB port on the PC
    2. Insert the remaining end of the USB cable into the handsets power interface connector
    3. If necessary, complete the [Found New Hardware] wizard on the PC (The PC will display [New Device Detected] and a new drive letter will be assigned for the handset)
    4. While in standby mode, press the Menu/OK key
    5. Select Tools (9)
    6. Select Mass Storage (1)
    7. Select Connect to PC (1), if the handset has established an active connection to the PC, the LCD will display [Connected to PC & Call disabled]
    8. Browse to the file(s) location on the PC & copy the file(s)
    9. Open the new drive letter (Removable Disk) for the handsets memory card
    10. Create a folder named DCIM then create a subfolder within the DCIM folder named 100SSMED
    11. Paste the file(s) into the DCIMs 100SSMED folder
    12. When you have copied & pasted all desired content press the left soft key for Done
    13. Select Yes (1)
    14. Disconnect the USB cable from both the PC & handset
    15. You will now be able to view the file(s) from the microSD memory card
    Or if you need the driver for other reasons I managed to find a link that works and is free for you. :)
    Just Click >>>HERE<<<
    Jul 19, 2010 | Samsung SPH-M500 Cellular Phone
    What i have to download for motorola w270 to get songs from my computer
    hey there.......to get songs from your computer - connect your phone to it using your data cable .....you can also use your memory card in a memory card reader and then connect it to the computer......put songs in your card then.....this shpuld help...
    Jul 29, 2009 | Motorola Cell Phones
    Unable to load file from PC
    1.) Select Memory Card in the handset : Main Menu > Multimedia > Music Library > Menu Key > Switch Storage Device > Memory Card.
    2.) Connect the Handset with PC using Data Cable.
    3.) You will get a prompt in the handset : Use as Mass Storage : Yes
    4.) Go to My Computer, you will find a removable drive.
    5.) Copy and Paste the Songs and Pictures in Removable Drive.
    6.) Make sure that the keypad of the handset should not be closed during the entire process.
    May 19, 2009 | Motorola Cell Phones
    I WANT TO CONNECT MY MOTOROLA W270 WITH MY PC BUT I CAN'T. SO PLEASE HELP ME TO CONNECT THE SAME
    TAKE YOUR USB CONNECT ONE END TO THE PHONE AND OTHER TO THE CPU THEN A MESSAGE WILL BE DISPLAYED ON YOUR PHONE CLICK YES AND THATS HOW U ARE CONNECTED IT SOMETIMES IN FIRST ATTEMPT TRY AGAIN IT WILL DEFINATELY CONNECT
    Feb 06, 2009 | Motorola Mobility W230 Phone US with...
    How to connect Motoyuva W270 with PC for internet purpose?
    Hi!
    As far as i know, no one has checked out pc suites of other motorola mobiles i guess.As of now, no pc suites available.
    As i use the same phone, its given in the manual that it supports only sandisk company micro SD memory cards to my horror.Somehow i got the fly mobile memory card working but this card doesn't work in other mobiles.The only way to get mp3 is to activate internet, GPRS and download songs.Else you got to use an adapter for the memory card, connect to pc, store info and go on with the mobile.You got no prob with connecting phone to pc or instead using an adapter for a memory card.
    Both the same.
    Anpother prob is that you will have a very low download speed through the internet.So, its better you connect memory card to the pc.
    Jan 02, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
    I want the site address for downloading pc suite for motoyuva w270 .
    i can help you..go here and download motorolaphone tools 5.
    http://rapidshare.com/files/116943918/Motorola_PhoneTools_v5.00_ENU.rar
    Dec 25, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
    Motorola w270- Memory Card not Recognised
    hi ,I have the same problem ....i tried inserting 2 memory cards ....both are not deducting
    Jul 09, 2008 | Cell Phones
    HTC G1 Logo
    289 people viewed this question
    Top HTC Computers & Internet Experts
    SANJEEV KUMAR SURI
    SANJEEV KUMAR SURI
    Tom Chichester
    Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
