Question about GE Ovens
My gas ge xl44 has a bad smell like propane when i turn on the oven what could this be i've cleaned it and checked the oven there is nothing burning how can i fix this???
fridgetech
  • 473 Answers
SOURCE: GE Profile TrueTemp Oven Model JGB908SEL1SS
Did you adjust the orifice on the saftey valve all the way down (turning it clockwise with a wrench)? The orifice is what the burner sits on top of.
Posted on Nov 07, 2007
docjohn174
  • 943 Answers
SOURCE: GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Posted on Sep 30, 2008
SOURCE: Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Posted on Feb 02, 2009
WRMtech
  • 70 Answers
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Posted on Feb 26, 2009
SOURCE: What are the instructions to clean my self
Do you have a model number?
XL44 is a line of ranges.
Instruction Manuals can be found HERE
Posted on Mar 20, 2009
I have a GE True Temp XL44 oven the stove burners work fine but the oven will not light. When I turn it on the oven, I do not smell any gas. What is the problem and how do I fix it?
could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
Feb 13, 2011 | GE Ovens
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
@yahoo.comi have a xl44 GE stove and the oven went out all of a sudden...no propane getting to pilot
Either you are out of propane or the regulator quit...
Check the tank and then replace the regulator...
heatman101
Sep 02, 2010 | Ovens
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Jul 02, 2010 | Ovens
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
Ge xl44 oven not igniting but burners ignite
Feb 26, 2009 | GE JGRP17 Gas Single Oven
XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Nov 27, 2008 | GE Ovens
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Ovens Logo
207 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
