Question about Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum
Bissell Momentum roller brush doesn't roll w/ pressure
Bissell Momentum roller brush does not want to work when it touches the floor. It works well until pressure from the floor stops it, no matter how little pressure is used or what height I adjust it to.
  • Anonymous Mar 24, 2014
    dyson making a noise when using if i put it on its side with bristles not touching the floor the noise goes away also if i put a bit of pressure on the top of the plastic housing for the brush roller it stops any ideas what could be the issue . i recently changed the clutch mechanism as the belts had streatched but that went on withe no issues untill now ?
  • 38 Answers
This is going to sound funny, but check the wheels. Sounds like the pin or shaft that holds them is broke. Also check the tension on your belt. If the tension is to loose then the brush will have a hard time spinning.Good luck
Posted on Jul 26, 2009
Bissell proheat pet brush is spinning but loud noise and vibration at same time
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has not work properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 23, 2016 | Bissell Vacuums
Bissell brushes spin, but not on the carprets
Ava B.
Dec 22, 2016 | Bissell Vacuums
The brushes on my bissell quick steamer don't turn or anything
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
Ava B.
Nov 24, 2016 | Bissell Vacuums
Bissell power steamer brushes will not turn
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
Ava B.
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
How do I make the brush rotate on my Bissell preheat pet carpet cleaner
Ava B.
Feb 21, 2016 | Bissell Vacuums
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Belts aren't broke roller still won't roll
Belt dosent have to be broke it may be stretched. It needs around 30lbs of pressure to roll the brush on carpet.
If it dose not roll off carpet at all the brush bearing are locked up. You may be able to remove the roller and check theme. Most likely you wil need a new roller brush.
Aug 08, 2014 | Bissell 8910 ProHeat Clear View Upright...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Roller brush doesn't turn
Sometimes you have to replace the brush roll itself depending on what kind of vacuum you have.
Mar 10, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Dec 31, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell Vacuum - Momentum Cyclonic 1 ea Bagless Upright Vacuum Logo
779 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
