Question about SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive
HELP! How do I reformat a Smartdisk Crossfire from Mac to PC?
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
Firelite smartdisk does not mount on my Mac
Your drive may be in NTFS file format that is not supported natively by your mac, try looking for NTFS support or reformat your drive to FAT32.
May 02, 2012 | SmartDisk CrossFire Desktop FireWire/USB...
Firelite is formatted for mac only, how do i reformat it to windows or back to the original?
If you are reformatting the disk on a Mac, then open the Disk Utility, then click reformat, and choose the format FAT32. If you have it connected to your PC, go to my computer, right click and select reformat, then choose FAT32.
DISCLAIMER: REFORMATTING AND/OR FORMATTING WILL ERASE EVERYTHING THAT IS ON THE HARD DRIVE. MAKE SURE YOU HAVE EVERYTHING YOU WANT BACKED UP.
Hope this helps!
Apr 25, 2011 | SmartDisk FireLite 40 GB Hard Drive
Hi i have a smartdisk crossfire external harddrive which I have used to save my photos from a windows based pc. However I have now purchased a IMac and wish to be able to load my photos on to this. When I...
congratulations on switching to mac!plug the external hard drive back into the PC, and copy the photo's to the PC, now plug it into your mac and go to applications-utilities-disc utility, the external drive should be listed on the left,click on the erase tab, at the volume format select "ms-dos file system", then click the erase button, this will erase everything on the drive and set it up so your mac can use it (but its ok because you moved all your pictures to the PC) now you can go back to the PC and copy the pictures on the external drive and it will work with your mac.
Jul 04, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
I wish to use my hard drive on a new computer but i have lost the start up discs smartdisk crossfire xf160 for a mac
Don't use it. I used it and it fried on me. You may be able to download the start up from the website. If you plan on getting rid of it let me know. I'd like to buy it off of you for the circuit board. email: bizzybone@csufresno.edu
Dec 29, 2009 | SmartDisk Crossfire Desktop (xf160f) 160...
Ex.hard drive
If the hard drive isn't detected at all by your computer then it may be defective. If you can test it on Linux or Mac and see if those detect it, may just be a driver issue in Windows. You can also try going to Disk Management in Windows and seeing if its there and manually assigning a letter or if that doesn't work you can try a hard drive data recovery program from http://www.stellarinfo.com/download.htm. Hope it helps!
May 15, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
Smartdisk 160GB Crossfire hard drive
I had this same problem. One option is to open the smartdisk up. It should have a seagate ata drive inside. Attach it to a computer as a slave drive. Your dive will appear as a secondary drive on your computer. you should be able to get all your files off the drive. If your worried about voiding your computers warranty you can buy a usb adapter to make the drive act as an external drive. I highly recommend never using this drive again. I used it as my main hard drive and it fried on me. If you plan on getting rid of this drive let me. I need the circuit board to get my music files and portfolio off my failed drive. Thank you.
Mar 26, 2009 | SmartDisk Crossfire Desktop (xf160f) 160...
SmartDisk Crossfire Desktop Drive
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Apr 23, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
Accidental ejection
try turning the external drive off & wait a minute then turn it back on.if it works just drag what you want to transfer from your mac to the external drive and it should copy it to the drive.
Apr 06, 2008 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Crossfire 160gb external hard drive.
If the drive was formatted in a newer windows OS and it is the NTFS file system, the Mac OS will only have read access. You can check this by plugging it in and checking the properties. To solve this you can copy your stuff off and reformat in the FAT32 format, you will only lose the security features that NTFS offers.
Jan 29, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive Logo
176 people viewed this question
Top SmartDisk Computers & Internet Experts
 Ian Kayhan
Ian Kayhan
terminalcon
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
