Question about NordicTrack E4000 Treadmill
Left step yaws, the entire roatation mechanism on left side is loose compared to right side step. Right side step is firm and secure but left is loose like a tooth. What to do?
  • Anonymous Mar 26, 2014
    When stepping on right step you can feel resistance when you step on the left step it seems to slip ie no resistance.
    New Friend:
  • 64 Answers
This doesn't sound like a treadmill. If it's an elliptical or stepper, try tightening the crank arm.
Posted on Jul 27, 2009
Where is the yaw sensor located on a 2008 Pontiac Torrent?
yaw-xozrttqlr3qpoa0t2tmccx0o-1-0.png 1 - Floor Panel
2 - Console
3 - Yaw Rate and Lateral Acceleration Sensor
4 - Seat Belt Pretensioner - Right
5 - Inflatable Restraint Side Impact Sensor (SIS) - Right (ASF)
6 - Rollover Sensor (ASF)
7 - Inflatable Restraint Sensing and Diagnostic Module (SDM)
8 - Seat Belt Pretensioner - Left
9 - Inflatable Restraint Side Impact Sensor (SIS) - Left (ASF)
Apr 16, 2017 | Pontiac Cars & Trucks
Tip
Joystick fix in Battlefield Bad Company 2 for PC (and Vietnam)
In Bad Company 2 if you wish to use a joystick the yaw will be reversed. You want to yaw left and it goes right, go right it instead goes left. This will tell you how to fix that.<br /> <br /> Locate you settings in your My Documents\BFBC2\input folder<br /> <br /> There is a file called air.dbx. This is an XML file. Open it with wordpad so you can read it formatted.<br /> <br /> Search for <span><span>ConceptYaw by pressing ctrl+f.</span></span><br /> <span><span>Scroll down til you find <span>GameSharedResources.PadInputActionData</span></span></span><br /> <span><span><span>Below this line there is <span>&lt;field name="ScaleValue"&gt;1&lt;/field&gt;</span></span></span></span><br /> <span><span><span><span>Change the 1 to a -1</span></span></span></span><br /> <span><span><span><span>Save the file and load the game.</span></span></span></span><br /> <span><span><span><span>Now your yaw will work correctly.<br /></span></span></span></span><span><span><span></span></span></span>
on Mar 05, 2011 | Video Game Consoles & Games
Init unable 50
Solution 1:
  • Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position.
  • Slide the print head to the middle.
  • Check for any pieces of paper or staple , paper clip...
Solution 2:
  • Slide the print head over to the right side under the cover to make sure you clean the entire encoder strip.
  • With the lint free cloth, firmly grab the encoder strip on both sides and rub the cloth down the strip from one end to the other (left to right then right to left) at least three times.
Jul 13, 2016 | Office Equipment & Supplies
What is wrong with my ignition,when I put the key in it won't turn ?
I have seen this on many vehicles. It is entirely possible that when you last parked and shut it off you had the steering wheel turned to the left or right rather than centered straight ahead. The power steering was assisting with holding it in that position until you shut it off. At that time power assist stopped and the wheel is resting firmly against the theft lock mechanism. Grasp the steering wheel firmly and if your front wheels are pointed to the left then force the steering wheel to the left a bit more and turn the key will holding the wheel, if front wheels are to the pointing to the right then force the steering wheel to the right and turn the key. Try NOT to turn off the ignition with the wheels not pointed straight.
Jun 18, 2014 | 1A Auto Parts Vehicle Parts & Accessories
Third row seat latched on left but not right
I just ran into the exact problem with my 2004 Suburban. Once I got the seat to lay down all the other mechanisms worked as they should and I could get the seat in and out as usuall. I found this post below which explained how to get the seat down. Wish I could take credit for figuring it out on my own but I can't.
"After working on it for a couple of days here is what I did to remove the 3rd row seat.
On the rear lower right and left side there are plastic covers, if you push the seat material forward a little you can see a hole where a nut holds it on, remove the nut. On the left side pull back the plastic cover and you can see the wire and the lever that releases the seat. With my foot holding up the #1 release lever on the right side I used an open end wrench to push forward the left side lever and the seat folded down.
I then used the #2 and #3 levers to remove the seat.
To view the whole cable, open the lower seat cover, it is an overlapping plastic clip, My problem was a loose cable, similar to a brake cable on a bicycle, after fixing it I have had no problems."
To remove the nut I used an 8mm socket wrench. My problem was not a loose cable but the #1 mechanism wouldn't pull up all the way, I'm guessing because that left side locked in out of order. I pushed that left side lever down with a hard tool and had my 5yr old daughter pull up on the #1 and the seat folded right down.
Hope this helps if you havn't already gotten it fixed.
Apr 23, 2013 | 2000 Chevrolet Suburban
Blade MQX QUAD-COPTER
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Apr 22, 2013 | Toys
My Datamax I Class is only printing one one side of the label, is there an adjustment I can make?
1. Right side not printing. Rotate round green knob (possible black center) found on right side of printhead assembly clockwise (or if necessary, through entire range) printing at each stop to check, until printing is satisfactory. If not fixed, next step is to do "Burnline Adjustment" as described in Operator's Manual.
2. Left side not printing. Make sure that large green plastic printhead latch on right is pushed firmly toward back of printer while printhead is pressed down, to make positive lockdown of printhead. Try rotating round green knob described in (1) above through entire range, printing at each stop to check. If not fixed, next step is to do "Burnline Adjustment" as described in Operator's Manual.
Nov 23, 2012 | Datamax I-4208 Thermal Label Printer
Unable clean print50
or
If you need any kind of technical assistance then you can contact support cell at http://vtechsquad.com/printer-support/
Sep 05, 2012 | Brother MFC295CNAll-In-One InkJet Printer
Roatating noise that stops when turning left but makes when turn right have been told wheel bearings on right and hub bearing on left
its not common to have both left and right bearing bad, usually just one. jack car up so wheels are off the ground, put in gear, be careful and grab the coil spring, you should be able to feel vibrations through the spring. compare sides, one will feel "rough" and the other "smooth", the rough one is the side with bad bearings, yes the hub will need to be replaced. this rule works for the rears also, it just that you will be the one spinnng the wheel.
Oct 21, 2009 | 2000 Pontiac Grand Am GT
2000 F 250, right side bank will not fire
Sounds like the computer is not working right or something is not plugged in, recheck all connection.
Apr 23, 2009 | 2000 Ford F250 Super Duty Crew Cabs
NordicTrack E4000 Treadmill Logo
99 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
