Question about Samsung LN32B530 32 in. LCD HDTV
Samsung tv will not change source of picture when using d side buttons on tv or thru the remote
  • 294 Answers
Its pretty clear that there is no problem with the remote you have as both the options are not working in your case.. so why not see a expert in the locality.. its a small problem related to the connection on it. but dont do it your self.. as its a good TV .. take help from experts frens if u have 1.. also it won't cost u much if you call a mechanic.. hv nice time.. rate me!!
Posted on Jul 26, 2009
HOW DO I CHANGE MY TV VIDEO SOURCE TO THE HDMI1 VIDEO SOURCE USING MY REMOTE CONTROL
On my Samsung TV remote, there is a button that allowed me to access choosing the option of either HDMI, or antenna. As soon as I chose the right setting the picture was displayed. You may have to click around through the options until you find it.
Sep 18, 2014 | Dynex Televison & Video
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
The tv changes it source from cable to pc all on its own with no use of remote and the volume will not work
first disconnect the remote battery, if same problem then you have to take off the buttons on the tv and clean them from inside !
TV Repair Service Television Repair Tv Repair Toronto Mississauga...
Jan 13, 2014 | Samsung LN40B530 40 in. LCD HDTV
Samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Jun 01, 2012 | Samsung Televison & Video
I need a user Manual for a samsung plasma TV 42
if it is anything like mine you have to find the input you connected it to. use the source button on your remote or the source button on the TV . mine is the top button on the right side of the TV when you are facing it. Hope this helps
Jan 06, 2012 | Samsung Televison & Video
The colours on my tv screen are all green and distorted can you tell me what the problem is its a samsung and its only 2 years old
YOU MAY HAVE CONNECTED THE RECEIVER TO AN INPUT ON THE TV THAT IS INCORRECT FOR THE SIGNAL OUTPUT FROM THE RECEIVER.
GET YOUR TV BACK ON THE CORRECT INPUT OR CHANNEL...CYCLE YOUR TV THROUGH ITS INPUTS BY...PRESSING THE INPUT, SOURCE, OR TV/VIDEO BUTTON ON YOUR TV REMOTE OR THE TV ITSELF.
IF THE PICTURE IS NOT RESTORED, CHANGE YOU TV TO CHANNEL 3 OR 4 USING TV REMOTE OR THE TV ITSELF.
IF THIS IS A 2ND TV, TUNE YOUR TV TO CHANNEL 60-73 USING THE BUTTONS ON YOUR TV REMOTE OR THE TV ITSELF.
ONCE YOUR TV PICTURE IS RESTORED, PRESS AND RELEASE THE SAT MODE BUTTON ON YOUR REMOTE TO ENSURE YOU'RE IN THE PROPER MODE FOR CONTROLLING YOUR RECEIVER.
YOU CAN ACCESS YOUR FEATURES, SETTINGS ETC, ON YOUR MENU BUTTON ON YOUR TV REMOTE.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Samsung Televison & Video
I can't get the picture to fully fill the screen on my 46'' TV. Model code ln46a750r1fxza. Used the ''tools'' button on the remote and tried adjusting the picture size, but it did not correct the problem....
First set your tv to 16:9 aspect ratio. Then go to the source ie: Cable Box or Sat Box. Then go into the User Menu and find the Set Up or HD settings or picture settings. You need to set the Box to the "Stretch" setting. Right now your source box is set ot 4:3 aspect ratio.. If you have difficulty in changing the aspect ratio on the source box, call the Cable or Sat co. They can help you.
Jul 09, 2009 | Samsung Televison & Video
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
The screen is blue and says VIEDO 1 on it I have removed the batteries in the remote and unplugged the tv and unplugged the cable and I still can't get it to work???
You have to change the input / source setting on the TV. Samsung generally call this "source". Look for a button for that name on the remote, or on the front panel. Press it until it's set to "TV" or "CATV" or "ANT" and the picture returns. You may have to pause briefly while changing sources.
If you still can't change the source, please provide the model number.
May 14, 2008 | Samsung Televison & Video
Source picture changing by itself
litigation- O.k if your tv is cycling through the menu ect. it sounds like you have a bad tact switch.Try pressing the contol panel buttons repeatedly,most of the time the remote is used so the tact switches go bad. Try this out ,it may help to clean the contacts. Just make sure you press them alot,it helps most of the time,if not you may wind up in the repair shop.Have fun and let me know. cooltek Mar,4/08
Mar 04, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN32B530 32 in. LCD HDTV Logo
499 people viewed this question
Henry  Thomas
Henry Thomas
