Question about Refrigerators
Freezer is not keeping items solidly frozen. The
Freezer is not keeping items solidly frozen. The wall between the freezer and fridge is extremely hot to the touch where the doors seal.
  • 31 Answers
Sounds like your Condenser Fan located under the refrigerator is not working. The Condenser Fan keeps the Compressor cool and must be operational. It may be stopped up with dirt, etc. or it is just bad. Also check you Condenser Coil for being stopped up with dirt, etc. A vacuum cleaner with a crevice wand will do the job. Hope this helps! Handy Henry
Posted on Jul 26, 2009
Freezer will not freeze ice ceam
Before you go any further it is important that you check for freezer temps. Yes, you have frozen items but remember that water freezes at 32 degrees and many items will get hard at that temp. And also remember that the lower the temp the longer frozen items will keep.
But ice cream needs proper freezer temps close to zero degrees. Use a digital thermostat and check for your freezer temp - bet it it is no where near zero. I had the same problem and attributed it to the fact that I was not using a name brand ice cream!!!! I was wrong ! LOL.
Aug 31, 2015 | Refrigerators
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Both the Fridge and Freezer are not cold enough
OOOOOOOOOh, this fridge was made by a friend , let me help!!!!1 foot fromt he back to the wall and the problem is resolved. Enjoy
Sep 15, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Freezer gets ice on back wall but wont freeze , fridge either
Hi Brian,
I recommend that you set the freezer to a WARMER setting to avoid getting ice on the back of the freezer. The ice is preventing good air flow over the cooling plate and therefore is not keeping the items in your freezer cold enough. You will need to remove the ice - which can be a daunting task. If you are able to store all your frozen items somewhere else for a while, it would be best to let the whole thing thaw out. I can't find any specs on that fridge, but i would guess that it does not have an automatic defrost, which is, in part, what is causing your problem.
If you are in a humid climate this will happen more frequently - especially if you have the unit outdoors or in an unairconditioned area.
Jul 02, 2009 | Frigidaire Refrigerators
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer does not seem to keep things frozen in my refridgerator .
probable reason for this is that the thermostat controls freezer temp and freezer follows suit.
if temp in your garage is low ie in winter, then the fridge doesn't need to switch on and the freezer temp rises.
i know this sounds barmy but it is true
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Our Magic Chef fridge model # MCBR1000W does not seem to be keeping the fridge part cool enough, but still keeps the items in the freezer section frozen. The compressor is working, so not sure why this is...
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Magic Chef Refrigerators
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
